Datasheet Texas Instruments THS1009 — Даташит
СерияTHS1009
10-разрядный двухканальный АЦП, 8 MSPS, параллельный DSP/uP, автосканирование каналов, малое энергопотребление
THS1009: 10-Bit, 2 Analog Input, 8-MSPS Simultaneous Sampling A/D Converter datasheet
PDF, 305 Кб, Версия: A, Файл опубликован: 17 дек 2002
THS1009IDA
Статус продуктаВ производстве
THS1009IDA
N1
Pin32
Package TypeDA
Industry STD TermTSSOP
Package QTY46
МаркировкаTHS1009I
Width (мм)6.2
Length (мм)11
Thickness (мм)1.15
Max Height (мм)1.2
Parameters / ModelsTHS1009IDA
THS1009IDA
# Input Channels2
Analog Voltage AVDD(Max), В5.25
Analog Voltage AVDD(Min), В4.75
АрхитектураPipeline
Digital Supply(Max), В5.25
Digital Supply(Min), В3
INL(Max), +/-LSB1
Input Range(Max), В4
Input Range(Min), В1.4
Тип входаDifferential,Single-Ended
Integrated FeaturesN/A
InterfaceParallel
Multi-Channel ConfigurationSimultaneous Sampling
Рабочий диапазон температур, Cот -40 до 85
Package GroupTSSOP
Package Size: mm2:W x L, PKG32TSSOP: 89 mm2: 8.1 x 11(TSSOP)
Power Consumption(Typ), mW186
Reference ModeExt,Int
Разрешение, Bits10
SINAD, дБ59
SNR, дБ61
Sample Rate (max), SPS8MSPS
Sample Rate(Max), MSPS8
THD(Typ), дБ-64
THS1009IDA
  • Resetting Non-FIFO Variations of the 10-bit THS10064
    PDF, 38 Кб, Файл опубликован: 9 май 2002
    The THS1007 and THS1009 are non-FIFO variations of the THS10064. They require some special procedures for properly resetting and configuring the device. This application brief explains the necessary steps required to get reliable data from these 10-bit, two and four channel simultaneous sampling data converters.
  • Reading the Configuration Registers of the 10-bit THS10064, THS1007, THS10082
    PDF, 39 Кб, Файл опубликован: 9 май 2002
    The THS10064, THS1007, THS10082, and the THS1009 are 10-bit variations of the THS1206. A useful feature of the THS1206 is the ability to read back the configuration register values for verification of the user configuration settings. While not specifically mentioned in the data sheets, these 10-bit parts provide similar debug functions.
Серия: THS1009 (1)
  • Semiconductors> Data Converters> Analog-to-Digital Converters (ADCs)> Precision ADCs (<=10MSPS)
На английском языке: Datasheet Texas Instruments THS1009
