Datasheet Texas Instruments THS8133CPHP — Даташит
СерияTHS8133
МодельTHS8133CPHP
10-битный тройной ЦАП, 80 MSPS с генерацией трехуровневой синхронизации (совместим с HDTV) 48-HTQFP от 0 до 70
Datasheet
TSP
TRIPLE 10-BIT, 80 MSPS VIDEO D/A CONVERTER WITH TRI-LEVEL SYNC GENERATION WITH TRI-LEVEL SYNC GENERATION
THS8133CPHP
THS8133CPHP
727GS
THS8133CPHP
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
RoHSНе совместим
  • Analog Reconstruction Filter for HDTV Using THS8133, THS8134, THS8135, THS8200
    PDF, 58 Кб, Файл опубликован: 14 сен 2001
    The THS8133, THS8134, THS8135, and the THS8200 devices are part of a family of chips for graphics and video applications, which contain triple DACs that operate from 80 MSPS to 240 MSPS. For television applications, an analog low-pass filter is required to reconstruct the signal that is input to the monitor. High definition television (HDTV) requires a sampling frequency of 74.25 MHz and has pass-
Серия: THS8133 (1)
  • THS8133CPHP
  • Semiconductors > Video and Imaging > Video DACs
На английском языке: Datasheet Texas Instruments THS8133CPHP
