Datasheet Texas Instruments THS8134CPHP — Даташит
СерияTHS8134
МодельTHS8134CPHP
8-битный тройной ЦАП, 80 MSPS с генерацией трехуровневой синхронизации (совместим с HDTV) 48-HTQFP от 0 до 70
Datasheet
TSP
Микросхема Преобразователь DA, TRIPLE 8Bit/ 80MSPS VIDEO D/A CONVERTER WITH TRI-LEVEL SYNC GENERATION
THS8134CPHP
504 ₽
THS8134CPHP
537 ₽
THS8134CPHP
719 ₽
THS8134CPHP
1 201 ₽
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
RoHSНе совместим
  • Analog Reconstruction Filter for HDTV Using THS8133, THS8134, THS8135, THS8200
    PDF, 58 Кб, Файл опубликован: 14 сен 2001
    The THS8133, THS8134, THS8135, and the THS8200 devices are part of a family of chips for graphics and video applications, which contain triple DACs that operate from 80 MSPS to 240 MSPS. For television applications, an analog low-pass filter is required to reconstruct the signal that is input to the monitor. High definition television (HDTV) requires a sampling frequency of 74.25 MHz and has pass-
Серия: THS8134 (1)
  • THS8134CPHP
  • Semiconductors > Video and Imaging > Video DACs
На английском языке: Datasheet Texas Instruments THS8134CPHP
