Datasheet Texas Instruments THS8136PHP — Даташит
СерияTHS8136
МодельTHS8136PHP
Тройной 10-битный ЦАП для графики и видео со скоростью 180 MSPS 48-HTQFP от 0 до 70
THS8136 Triple 10-Bit 180-MSPS Graphics and Video DAC datasheet
PDF, 312 Кб, Версия: B, Файл опубликован: 24 апр 2013
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierJEDEC TRAY (10+1)
МаркировкаTHS8136
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Evaluation Modules & Boards: THS8135EVM
    THS8135 Evaluation Module
  • THS8135 PCB Layout Guidelines
    PDF, 147 Кб, Файл опубликован: 29 июн 2010
  • Analog Reconstruction Filter for HDTV Using THS8133, THS8134, THS8135, THS8200
    PDF, 58 Кб, Файл опубликован: 14 сен 2001
    The THS8133, THS8134, THS8135, and the THS8200 devices are part of a family of chips for graphics and video applications, which contain triple DACs that operate from 80 MSPS to 240 MSPS. For television applications, an analog low-pass filter is required to reconstruct the signal that is input to the monitor. High definition television (HDTV) requires a sampling frequency of 74.25 MHz and has pass-
Серия: THS8136 (4)
  • Semiconductors > Video and Imaging > Video DACs
На английском языке: Datasheet Texas Instruments THS8136PHP
