Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI THS8200PFP — Даташит
СерияTHS8200
МодельTHS8200PFP
Datasheet Texas Instruments THS8200PFP
Тройной 10-битный ЦАП для всех форматов видео 80-HTQFP от 0 до 70
THS8200 All-Format Oversampled Component Video/PC Graphics D/A System With Three 11-Bit DACs, CGMS Data Insertion datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 18 сен 2014
  • THS8200 PCB Layout Guidelines
    PDF, 40 Кб, Файл опубликован: 16 июн 2010
  • Analog Reconstruction Filter for HDTV Using THS8133, THS8134, THS8135, THS8200
    PDF, 58 Кб, Файл опубликован: 14 сен 2001
    The THS8133, THS8134, THS8135, and the THS8200 devices are part of a family of chips for graphics and video applications, which contain triple DACs that operate from 80 MSPS to 240 MSPS. For television applications, an analog low-pass filter is required to reconstruct the signal that is input to the monitor. High definition television (HDTV) requires a sampling frequency of 74.25 MHz and has pass-
  • High Resolution Video Using the DM642 DSP and the THS8200 Driver (Rev. A)
    PDF, 440 Кб, Версия: A, Файл опубликован: 3 май 2004
    The DM642 DSP has three 20-bit video ports capable of high definition (HD) display. The video ports can be programmed to follow HDTV standards, such as SMPTE274M and SMPTE296M. These HDTV standards follow a 4:2:2 convention where luminance and chrominance signals are separated onto two different 8- or 10-bit data paths. This convention is more commonly called Y/C mode. Many new HD displays accept
Серия: THS8200 (1)
  • THS8200PFP
  • Semiconductors > Video and Imaging > Video DACs
На английском языке: Datasheet Texas Instruments THS8200PFP
Политика конфиденциальности
