Datasheet Texas Instruments TL16C750FNR — Даташит
СерияTL16C750
МодельTL16C750FNR
Один UART с 64-байтовым Fifos, автоматическим управлением потоком, режимами низкого энергопотребления 44-PLCC от 0 до 70
Asynchronous Communications Element With 64-Byte FIFOs And AutoFlow Control datasheet
PDF, 516 Кб, Версия: C, Файл опубликован: 10 дек 1997
Pin44
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Package QTY500
МаркировкаTL16C750FN
Width (мм)16.59
Length (мм)16.59
Thickness (мм)4.06
Max Height (мм)4.57
Auto RTS/CTSYes
Baud Rate (max) at Vcc = 1.8V and with 16X SamplingN/A Mbps
Baud Rate (max) at Vcc = 2.5V and with 16X SamplingN/A Mbps
Baud Rate (max) at Vcc = 3.3V and with 16X Sampling0.875 Mbps
Baud Rate (max) at Vcc = 5.0V and with 16X Sampling1 Mbps
CPU InterfaceX86
FIFOs64 bytes
Количество каналов1
Operating Voltage3.3,5 В
Package GroupPLCC
Programmable FIFO Trigger LevelsNo
Rx FIFO Trigger Levels4
Tx FIFO Trigger LevelsN/A
  • Low Voltage Modem Platform Based on TMS320LC56
    PDF, 205 Кб, Файл опубликован: 1 янв 1997
    This application report presents a modem reference design based on the TMS320LC56 DSP. The advanced peripherals of this device provide the features necessary for integration into complex systems optimizing access times and minimizing external logic. A software analysis at the beginning shows that the computing power of the LC56 is sufficient to support even the highest standards of voice and data
Серия: TL16C750 (4)
  • Semiconductors > Interface > UART
На английском языке: Datasheet Texas Instruments TL16C750FNR
