Datasheet ТI TL750M05 — Даташит
| Серия | TL750M05 |
LDO с одним выходом, 750 мА, фиксированный (5,0 В), низкий ток покоя, защита от сброса нагрузки 60 В
Datasheet
| TL750M05CKC | TL750M05CKCE3 | TL750M05CKTER | TL750M05CKTPR | TL750M05CKTPRG3 | |
| Статус продукта | Снят с производства | Снят с производства | Снят с производства | Снят с производства | Снят с производства |
| Доступность образцов у производителя | Нет | Нет | Нет | Нет | Нет |
| N | 1 | 2 | 3 | 4 | 5 |
| Pin | 3 | 3 | 3 | 2 | 2 |
| Package Type | KC | KC | KTE | KTP | KTP |
| Industry STD Term | TO-220 | TO-220 | PFM | PFM | PFM |
| JEDEC Code | R-PSFM-T | R-PSFM-T | R-PSFM-G | R-PSFM-G | R-PSFM-G |
| Маркировка | TL750M05C | TL750M05C | TL750M05C | 750M05C | |
| Width (мм) | 9.02 | 9.02 | 8 | 6.15 | 6.15 |
| Length (мм) | 10.17 | 10.17 | 9.4 | 6.04 | 6.04 |
| Thickness (мм) | 4.58 | 4.58 | 1.91 | 1.91 | 1.91 |
| Pitch (мм) | 2.54 | 2.54 | 2.54 | 4.57 | 4.57 |
| Max Height (мм) | 4.7 | 4.7 | 2.03 | 2.03 | 2.03 |
| Mechanical Data | Скачать | Скачать | Скачать | Скачать | Скачать |
| Parameters / Models | TL750M05CKC![]() | TL750M05CKCE3![]() | TL750M05CKTER![]() | TL750M05CKTPR![]() | TL750M05CKTPRG3![]() |
| Accuracy(%) | 1 | 1 | 1 | 1 | 1 |
| Additional Features | Overcurrent Protection Thermal Shutdown | Overcurrent Protection Thermal Shutdown | Overcurrent Protection Thermal Shutdown | Overcurrent Protection Thermal Shutdown | Overcurrent Protection Thermal Shutdown |
| Approx. Price (US$) | 0.42 | 1ku | 0.42 | 1ku | 0.42 | 1ku | 0.42 | 1ku | 0.42 | 1ku |
| Fixed Output Options(V) | 5 | 5 | 5 | 5 | 5 |
| Iout(Max)(A) | 0.75 | 0.75 | 0.75 | 0.75 | 0.75 |
| Iq(Typ)(mA) | 5 | 5 | 5 | 5 | 5 |
| Noise(uVrms) | 500 | 500 | 500 | 500 | |
| Operating Temperature Range(C) | 0 to 125 | 0 to 125 | 0 to 125 | 0 to 125 | 0 to 125 |
| Output Capacitor Type | Non-Ceramic | Non-Ceramic | Non-Ceramic | Non-Ceramic | Non-Ceramic |
| Output Options | Fixed Output | Fixed Output | Fixed Output | Fixed Output | Fixed Output |
| Package Group | TO-220 | TO-220 | DDPAK/TO-263 TO-220 TO-252 | DDPAK/TO-263 TO-220 TO-252 | DDPAK/TO-263 TO-220 TO-252 |
| Package Size: mm2:W x L (PKG) | See datasheet (TO-220) | See datasheet (TO-220) | See datasheet (TO-220) See datasheet (PFM) | See datasheet (TO-220) See datasheet (PFM) | See datasheet (TO-220) See datasheet (PFM) |
| Powered Load | FPGA Microcontroller Microprocessor | FPGA Microcontroller Microprocessor | FPGA Microcontroller Microprocessor | FPGA Microcontroller Microprocessor | |
| Rating | Catalog | Catalog | Catalog | Catalog | Catalog |
| Regulated Outputs(#) | 1 | 1 | 1 | 1 | 1 |
| Vdo(Typ)(mV) | 600 | 600 | 600 | 600 | 600 |
| Vin(Max)(V) | 26 | 26 | 26 | 26 | 26 |
| Vin(Min)(V) | 6 | 6 | 6 | 6 | 6 |
| Vout(Max)(V) | 5 | 5 | 5 | 5 | 5 |
| Vout(Min)(V) | 5 | 5 | 5 | 5 | 5 |
| RoHS | Не совместим | Не совместим | Не совместим | Не совместим | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет | Нет | Нет | Нет | Нет |
- Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TL750M05 (5)
- Semiconductors> Power Management> Linear Regulator (LDO)> Single Channel LDO
