Datasheet Texas Instruments TL751L10 — Даташит
СерияTL751L10
LDO с одним выходом, 150 мА, фиксированный (10,0 В), низкий ток покоя, защита от сброса нагрузки 60 В
TL751L10QDTL751L10QP
Статус продуктаСнят с производстваСнят с производства
N12
Pin88
Package TypeDP
Industry STD TermSOICPDIP
JEDEC CodeR-PDSO-GR-PDIP-T
Width (мм)3.916.35
Length (мм)4.99.81
Thickness (мм)1.583.9
Pitch (мм)1.272.54
Max Height (мм)1.755.08
Parameters / ModelsTL751L10QD
TL751L10QD
TL751L10QP
TL751L10QP
Accuracy(%)44
Additional FeaturesEnable
Overcurrent Protection
Thermal Shutdown
Enable
Thermal Shutdown
Approx. Price (US$)0.20 | 1ku0.20 | 1ku
Fixed Output Options(V)1010
Iout(Max)(A)0.150.15
Iq(Typ)(mA)11
Noise(uVrms)700700
Operating Temperature Range(C)0 to 1250 to 125
Output Capacitor TypeCap Free
Non-Ceramic
Cap Free
Non-Ceramic
Output OptionsFixed OutputFixed Output
Package GroupSOICPDIP
Package Size: mm2:W x L (PKG)See datasheet (PDIP)See datasheet (PDIP)
Powered LoadFPGA
Microcontroller
Microprocessor
FPGA
Microcontroller
Microprocessor
RatingCatalogCatalog
Regulated Outputs(#)11
Vdo(Typ)(mV)600600
Vin(Max)(V)2626
Vin(Min)(V)1111
Vout(Max)(V)1010
Vout(Min)(V)1010
RoHSНе совместимНе совместим
Бессвинцовая технология (Pb Free)НетНет
  • Technical Review of Low Dropout Voltage Regulator Operation And Performance
    PDF, 284 Кб, Файл опубликован: 30 авг 1999
    This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
Серия: TL751L10 (2)
  • Semiconductors> Power Management> Linear Regulator (LDO)> Single Channel LDO
На английском языке: Datasheet Texas Instruments TL751L10
