Datasheet Texas Instruments TL7702ACP — Даташит
Серия | TL7702A |
Модель | TL7702ACP |
Одиночный SVS с программируемым порогом УФ-излучения и задержкой сброса 8-PDIP 0–70
TL77xxA Supply-Voltage Supervisors datasheet
PDF, 1.5 Мб, Версия: K, Файл опубликован: 29 сен 2016
Pin | 8 |
Package Type | P |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 50 |
Carrier | TUBE |
Маркировка | TL7702ACP |
Width (мм) | 6.35 |
Length (мм) | 9.81 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 1800 uA |
Monitored Voltage 1 (typ)(Nom) | Adjustable В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Рабочий диапазон температур | от -40 до 85,0 до 70 C |
Output Driver Type / Reset Output | Active-high,Active-low,Open-drain |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 2 % |
Special Features | Manual Reset |
Threshold Voltage 1(Typ) | 2.53 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | Programmable ms |
VCC(Max) | 18 В |
VCC(Min) | 3.5 В |
Watchdog Timer WDI | None sec |
Бессвинцовая технология (Pb Free) | Да |
- Supply Voltage Supervisor TL77xx SeriesPDF, 389 Кб, Файл опубликован: 1 янв 1997
Reliable operation of a circuit or system requires the supply voltage to be between certain limits. A voltage monitor is thus required to check the supply voltage and provide a signal to the controlled circuit, to reset or re-initialize the system whenever the supply voltage has failed. For this purpose Texas Instruments developed the supply voltage supervisor series TL77xx, which offers these fu
Серия: TL7702A (14)
- Semiconductors > Power Management > Supervisor and Reset IC
