Datasheet Texas Instruments TL7702AIDRG4 — Даташит
СерияTL7702A
МодельTL7702AIDRG4
Одиночный SVS с программируемым УФ-порогом и задержкой сброса 8-SOIC от -40 до 85
TL77xxA Supply-Voltage Supervisors datasheet
PDF, 1.5 Мб, Версия: K, Файл опубликован: 29 сен 2016
Чип контроля напряжения, 2.53V Supply Voltage Supervisor 0V to 6V 1 Active High/Active Low 8Pin SOIC T/R
TL7702AIDRG4
14 ₽
TL7702AIDRG4
14 ₽
TL7702AIDRG4
198 ₽
ТаймЧипс
TL7702AIDRG4
Package TypeD
Package QTY2500
Маркировка7702AI
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
# of Supplies Monitored1
Iq(Typ)1800 uA
Monitored Voltage 1 (typ)(Nom)Adjustable В
Monitored Voltage 2 (typ)(Nom)N/A В
Output Driver Type / Reset OutputActive-high,Active-low,Open-drain
Reset Threshold Accuracy2 %
Special FeaturesManual Reset
Threshold Voltage 1(Typ)2.53 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time DelayProgrammable ms
VCC(Max)18 В
VCC(Min)3.5 В
Watchdog Timer WDINone sec
  • Supply Voltage Supervisor TL77xx Series
    PDF, 389 Кб, Файл опубликован: 1 янв 1997
    Reliable operation of a circuit or system requires the supply voltage to be between certain limits. A voltage monitor is thus required to check the supply voltage and provide a signal to the controlled circuit, to reset or re-initialize the system whenever the supply voltage has failed. For this purpose Texas Instruments developed the supply voltage supervisor series TL77xx, which offers these fu
  • Semiconductors > Power Management > Supervisor and Reset IC
На английском языке: Datasheet Texas Instruments TL7702AIDRG4
