Datasheet Texas Instruments TL7702AIDE4 — Даташит
| Серия | TL7702A |
| Модель | TL7702AIDE4 |
Одиночный SVS с программируемым УФ-порогом и задержкой сброса 8-SOIC от -40 до 85
TL77xxA Supply-Voltage Supervisors datasheet
PDF, 1.5 Мб, Версия: K, Файл опубликован: 29 сен 2016
Купить TL7702AIDE4 на РадиоЛоцман.Цены — от 19 до 1 162 ₽8 предложений от 8 поставщиков Чип контроля напряжения, 2.53V Supply Voltage Supervisor 0V to 6V 1 Active High/Active Low 8Pin SOIC Tube | |||
| TL7702AIDE4 Texas Instruments | 19 ₽ | ||
| TL7702AIDE4 Texas Instruments | 1 162 ₽ | ||
| TL7702AIDE4 Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 75 |
| Carrier | TUBE |
| Маркировка | 7702AI |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| # of Supplies Monitored | 1 |
| Iq(Typ) | 1800 uA |
| Monitored Voltage 1 (typ)(Nom) | Adjustable В |
| Monitored Voltage 2 (typ)(Nom) | N/A В |
| Рабочий диапазон температур | от -40 до 85,0 до 70 C |
| Output Driver Type / Reset Output | Active-high,Active-low,Open-drain |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
| Rating | Catalog |
| Reset Threshold Accuracy | 2 % |
| Special Features | Manual Reset |
| Threshold Voltage 1(Typ) | 2.53 В |
| Threshold Voltage 2 (typ)(Typ) | N/A В |
| Time Delay | Programmable ms |
| VCC(Max) | 18 В |
| VCC(Min) | 3.5 В |
| Watchdog Timer WDI | None sec |
- Supply Voltage Supervisor TL77xx SeriesPDF, 389 Кб, Файл опубликован: 1 янв 1997
Reliable operation of a circuit or system requires the supply voltage to be between certain limits. A voltage monitor is thus required to check the supply voltage and provide a signal to the controlled circuit, to reset or re-initialize the system whenever the supply voltage has failed. For this purpose Texas Instruments developed the supply voltage supervisor series TL77xx, which offers these fu
Серия: TL7702A (14)
- Semiconductors > Power Management > Supervisor and Reset IC
