Datasheet Texas Instruments TL7702AIDR — Даташит
Серия | TL7702A |
Модель | TL7702AIDR |
Одиночный SVS с программируемым УФ-порогом и задержкой сброса 8-SOIC от -40 до 85
TL77xxA Supply-Voltage Supervisors datasheet
PDF, 1.5 Мб, Версия: K, Файл опубликован: 29 сен 2016
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | 7702AI |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
# of Supplies Monitored | 1 |
Iq(Typ) | 1800 uA |
Monitored Voltage 1 (typ)(Nom) | Adjustable В |
Monitored Voltage 2 (typ)(Nom) | N/A В |
Рабочий диапазон температур | от -40 до 85,0 до 70 C |
Output Driver Type / Reset Output | Active-high,Active-low,Open-drain |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Reset Threshold Accuracy | 2 % |
Special Features | Manual Reset |
Threshold Voltage 1(Typ) | 2.53 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | Programmable ms |
VCC(Max) | 18 В |
VCC(Min) | 3.5 В |
Watchdog Timer WDI | None sec |
- Supply Voltage Supervisor TL77xx SeriesPDF, 389 Кб, Файл опубликован: 1 янв 1997
Reliable operation of a circuit or system requires the supply voltage to be between certain limits. A voltage monitor is thus required to check the supply voltage and provide a signal to the controlled circuit, to reset or re-initialize the system whenever the supply voltage has failed. For this purpose Texas Instruments developed the supply voltage supervisor series TL77xx, which offers these fu
Серия: TL7702A (14)
- Semiconductors > Power Management > Supervisor and Reset IC
