Datasheet Texas Instruments TL7709ACP — Даташит
СерияTL7709A
МодельTL7709ACP
Одиночный SVS для систем 9 В с программируемой временной задержкой 8-PDIP 0–70
TL77xxA Supply-Voltage Supervisors datasheet
PDF, 1.5 Мб, Версия: K, Файл опубликован: 29 сен 2016
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаTL7709ACP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
# of Supplies Monitored1
Iq(Typ)1800 uA
Monitored Voltage 1 (typ)(Nom)9 В
Monitored Voltage 2 (typ)(Nom)N/A В
Output Driver Type / Reset OutputActive-high,Active-low,Open-drain
Package GroupPDIP
Reset Threshold Accuracy2 %
Special FeaturesManual Reset
Threshold Voltage 1(Typ)7.6 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time DelayProgrammable ms
VCC(Max)18 В
VCC(Min)3.5 В
Watchdog Timer WDINone sec
  • Supply Voltage Supervisor TL77xx Series
    PDF, 389 Кб, Файл опубликован: 1 янв 1997
    Reliable operation of a circuit or system requires the supply voltage to be between certain limits. A voltage monitor is thus required to check the supply voltage and provide a signal to the controlled circuit, to reset or re-initialize the system whenever the supply voltage has failed. For this purpose Texas Instruments developed the supply voltage supervisor series TL77xx, which offers these fu
  • Semiconductors > Power Management > Supervisor and Reset IC
На английском языке: Datasheet Texas Instruments TL7709ACP
