Datasheet Texas Instruments TL7733BCDE4 — Даташит
СерияTL7733B
МодельTL7733BCDE4
Одиночный контроллер напряжения питания 8-SOIC 0–70
TL7702B, TL7733B, and TL7705B Supply-Voltage Supervisors datasheet
PDF, 974 Кб, Версия: N, Файл опубликован: 1 сен 2019
Package TypeD
Package QTY75
Маркировка7733BC
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
# of Supplies Monitored1
Iq(Typ)1800 uA
Monitored Voltage 1 (typ)(Nom)3.3 В
Monitored Voltage 2 (typ)(Nom)N/A В
Output Driver Type / Reset OutputActive-high,Active-low,Open-drain
Reset Threshold Accuracy2.6 %
Special FeaturesManual Reset
Threshold Voltage 1(Typ)3.08 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time DelayProgrammable ms
VCC(Max)18 В
VCC(Min)3.6 В
Watchdog Timer WDINone sec
  • Supply Voltage Supervisor TL77xx Series
    PDF, 389 Кб, Файл опубликован: 1 янв 1997
    Reliable operation of a circuit or system requires the supply voltage to be between certain limits. A voltage monitor is thus required to check the supply voltage and provide a signal to the controlled circuit, to reset or re-initialize the system whenever the supply voltage has failed. For this purpose Texas Instruments developed the supply voltage supervisor series TL77xx, which offers these fu
  • Semiconductors > Power Management > Supervisor and Reset IC
На английском языке: Datasheet Texas Instruments TL7733BCDE4
