Datasheet Texas Instruments TLC320AC02CFN — Даташит
СерияTLC320AC02
МодельTLC320AC02CFN
Одноканальный кодек, пропускная способность не зависит от частоты дискретизации 28-PLCC от 0 до 70
Single-Supply Analog Interface Circuit datasheet
PDF, 803 Кб, Версия: C, Файл опубликован: 22 окт 1997
19 предложений от 17 поставщиков
IC BANDWITH CODEC 1-CH 28-PLCC. Audio Interface 14 b Serial 28-PLCC (11.51x11.51). Interface - CODECs
TLC320AC02CFN
333 ₽
Рутоника
TLC320AC02CFN
967 ₽
TLC320AC02CFN
1 035 ₽
SUV System
TLC320AC02CFN
Pin2828
Package TypeFNFN
Industry STD TermPLCCPLCC
JEDEC CodeS-PQCC-JS-PQCC-J
Package QTY3737
CarrierTUBETUBE
МаркировкаTLC320AC02CFN
Width (мм)11.5111.51
Length (мм)11.5111.51
Thickness (мм)4.064.06
Pitch (мм)1.271.27
Max Height (мм)4.574.57
Analog Inputs2
Analog Outputs1
Package Size: mm2:W x L64LQFP: 144 mm2: 12 x 12(LQFP),28PLCC: 132 mm2: 11.51 x 11.51(PLCC) PKG
Sampling Rate(Max)25 kHz
  • Interfacing Two Analog Interface Circuits to One TMS320C5x Serial Port
    PDF, 83 Кб, Файл опубликован: 1 июн 1997
    In some cases, such as wireless communications applications, a system requires two communication channels but only one serial port is available. This document shows how to multiplex this port and how to interface two analog lines. There is a schematic, and an example of code is given. The analog interface circuits (AICs) chosen for this solution were purposely selected to address as many potential
  • Multiple TLC320AC01/02 Analog I/F Circuits on One TMS320C5x DSP Serial Port
    PDF, 54 Кб, Файл опубликован: 19 авг 1996
    Many applications require a DSP to obtain information from multiple A/D channels and transmit to multiple D/A channels. This document provides the hardware and software for the connection between two AIC channels and one DSP serial port. The AIC connects to the 16-bit fixed-point DSP in the master/slave mode with no external hardware required. A summary of the AIC master/slave operation is incl
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLC320AC02CFN
