Datasheet Texas Instruments TLC320AC02IFNR — Даташит
Серия | TLC320AC02 |
Модель | TLC320AC02IFNR |
Одноканальный кодек — полоса пропускания не зависит от частоты дискретизации 28-PLCC от -40 до 85
Single-Supply Analog Interface Circuit datasheet
PDF, 803 Кб, Версия: C, Файл опубликован: 22 окт 1997
![]() 19 предложений от 15 поставщиков IC AUDIO BAND CODEC 14BIT 28PLCC. Audio Interface 14 b Serial 28-PLCC (11.51x11.51). Interface - CODECs | |||
TLC320AC02IFNR Texas Instruments | от 63 ₽ | ||
TLC320AC02IFNR Texas Instruments | 1 575 ₽ | ||
TLC320AC02IFNR Texas Instruments | 5 879 ₽ | ||
TLC320AC02IFNR Texas Instruments | по запросу |
Pin | 28 | 28 |
Package Type | FN | FN |
Industry STD Term | PLCC | PLCC |
JEDEC Code | S-PQCC-J | S-PQCC-J |
Package QTY | 750 | 750 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | TLC | 320AC02IFN |
Width (мм) | 11.51 | 11.51 |
Length (мм) | 11.51 | 11.51 |
Thickness (мм) | 4.06 | 4.06 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 4.57 | 4.57 |
Analog Inputs | 2 |
Analog Outputs | 1 |
Package Size: mm2:W x L | 64LQFP: 144 mm2: 12 x 12(LQFP),28PLCC: 132 mm2: 11.51 x 11.51(PLCC) PKG |
Sampling Rate(Max) | 25 kHz |
- Interfacing Two Analog Interface Circuits to One TMS320C5x Serial PortPDF, 83 Кб, Файл опубликован: 1 июн 1997
In some cases, such as wireless communications applications, a system requires two communication channels but only one serial port is available. This document shows how to multiplex this port and how to interface two analog lines. There is a schematic, and an example of code is given. The analog interface circuits (AICs) chosen for this solution were purposely selected to address as many potential - Multiple TLC320AC01/02 Analog I/F Circuits on One TMS320C5x DSP Serial PortPDF, 54 Кб, Файл опубликован: 19 авг 1996
Many applications require a DSP to obtain information from multiple A/D channels and transmit to multiple D/A channels. This document provides the hardware and software for the connection between two AIC channels and one DSP serial port. The AIC connects to the 16-bit fixed-point DSP in the master/slave mode with no external hardware required. A summary of the AIC master/slave operation is incl - Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
- Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP PortPDF, 105 Кб, Файл опубликован: 8 июл 2009
This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications - Out-of-Band Noise Measurement Issues for Audio CodecsPDF, 145 Кб, Файл опубликован: 6 дек 2006
- Audio Serial Interface Configurations for Audio CodecsPDF, 70 Кб, Файл опубликован: 22 сен 2010
An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock - Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECsPDF, 291 Кб, Файл опубликован: 27 сен 2000
This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies. - Control Port And Reset Operation SoundPlus Audio Converters and CODECsPDF, 77 Кб, Файл опубликован: 27 сен 2000
This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter. - Solving Enumeration Errors in USB Audio DAC and CODEC DesignsPDF, 157 Кб, Файл опубликован: 30 окт 2009
TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
Серия: TLC320AC02 (5)
- TLC320AC02CFN TLC320AC02CPM TLC320AC02IFN TLC320AC02IFNR TLC320AC02IPM
- Semiconductors > Audio > Audio Converters > Audio CODEC
