Datasheet Texas Instruments TLC320AD50CPTR — Даташит
СерияTLC320AD50
МодельTLC320AD50CPTR
Одноканальный кодек с функцией Master-Slave (3 ведомых) и соотношением сигнал/шум 89 дБ 48-LQFP
Sigma-Delta Analog Interface Circuits With Master-Slave Function datasheet
PDF, 918 Кб, Версия: E, Файл опубликован: 13 окт 2000
IC CODEC 16BIT SER 48-LQFP. General Purpose Interface 16 b Serial 48-LQFP (7x7). Interface - CODECs
TLC320AD50CPTR
3 831 ₽
Элитан
TLC320AD50CPTR
7 756 ₽
Hi-Tech Circuit Group
TLC320AD50CPTR
МосЧип
TLC320AD50CPTR
Pin48
Package TypePT
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаP320AD50
Width (мм)7
Length (мм)7
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
Analog Inputs2
Analog Outputs2
Package Size: mm2:W x L48LQFP: 81 mm2: 9 x 9(LQFP),28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG
Sampling Rate(Max)22.05 kHz
  • Evaluation Modules & Boards: TLC320AD50-EVM
    TLC320AD50 AIC Evaluation Module
  • Design Guidelines for the TLC320AD50
    PDF, 70 Кб, Файл опубликован: 2 дек 1999
    This document provides board-level guidelines and techniques for designing with the TLC320AD50. This includes topics such as printed-circuit board construction, power-supply decoupling, noise reduction, and general design guidelines. The intent is to provide strategies to help users attain first-pass design sucess with the TLC320AD50.
  • Comparison of TI Voiceband Codecs for Telephony Applications
    PDF, 79 Кб, Файл опубликован: 8 дек 1999
    This application report describes the different types of voice-band CODECs for telephony applications such as client modem analog interface circuits, central office line card CODEC/filter combos, and voice-band audio processors. A summary of the characteristics of each is included.This report focuses on the recommended client modem analog interface circuits (AICs) fabricated by Texas Instrumen
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
Серия: TLC320AD50 (4)
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLC320AD50CPTR
