Datasheet Texas Instruments TLC7705MUB — Даташит
Серия | TLC7705M |
Модель | TLC7705MUB |
SVS с одинарным питанием (5 В) с программируемой задержкой времени и двухтактными выходами 10-CFP от -55 до 125
MicroPower Supply Voltage Supervisors. datasheet
PDF, 1.9 Мб, Версия: M, Файл опубликован: 19 мар 2012
![]() 7 предложений от 7 поставщиков Чип контроля напряжения, Supply Voltage Supervisory 5V 10Pin CFPAK Tube | |||
TLC7705MUB Texas Instruments | 3 317 ₽ | ||
TLC7705MUB Texas Instruments | по запросу | ||
Pin | 10 | 10 |
Package Type | U | U |
Industry STD Term | CFP | CFP |
JEDEC Code | S-GDFP-F | S-GDFP-F |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | 9751301QHA | TLC7705M |
Width (мм) | 6.35 | 6.35 |
Length (мм) | 6.35 | 6.35 |
Thickness (мм) | 1.65 | 1.65 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 |
# of Supplies Monitored | 1 |
Iq(Typ) | 9 uA |
Monitored Voltage 1 (typ)(Nom) | 5 В |
Output Driver Type / Reset Output | Active-high,Active-low,Push-pull |
Package Group | CFP |
Package Size: mm2:W x L | See datasheet (CFP) PKG |
Rating | Military |
Reset Threshold Accuracy | 1.8 % |
Threshold Voltage 1(Typ) | 4.55 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | Programmable ms |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Watchdog Timer WDI | None sec |
RoHS | See ti.com |
- TLC770x Series of BiCMOS Supply Voltage SupervisorsPDF, 327 Кб, Файл опубликован: 1 янв 1995
This report describes the function and application of the supply voltage supervisor circuit TLC770X. Besides a detailed functional description, the behavior of line and battery operated power supplies during power-up as well as the behavior of digital circuits is presented. Finally application-examples of supply voltage supervision in general and supply voltage supervision in systems are described - Reset Circuit for the TMS320C6000 DSP (Rev. A)PDF, 36 Кб, Версия: A, Файл опубликован: 10 июн 1999
This document describes two solutions used to provide a reset circuit to the Texas Instruments (TI)(tm) TMS320C6000 digital signal processor (DSP). One solution sets a supply voltage supervisor, such as the TI TLC7733 and TLC7725, on each of the supply voltages, DVdd and CVdd. Another solution monitors both the 2.5-V/1.8-V and 3.3-V power supplies using a single supervisor such as the TI TPS3707.
Серия: TLC7705M (7)
- Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
