Datasheet Texas Instruments TLC7705MJG — Даташит
Серия | TLC7705M |
Модель | TLC7705MJG |
SVS с одинарным питанием (5 В) с программируемой задержкой и двухтактными выходами 8-CDIP от -55 до 125
MicroPower Supply Voltage Supervisors. datasheet
PDF, 1.9 Мб, Версия: M, Файл опубликован: 19 мар 2012
![]() 6 предложений от 6 поставщиков Чип контроля напряжения, Processor Supervisor 4.55V 1 8Pin CDIP Tube | |||
TLC7705MJG Texas Instruments | 1 775 ₽ | ||
TLC7705MJG Texas Instruments | 2 691 ₽ | ||
TLC7705MJG Texas Instruments | 3 392 ₽ | ||
TLC7705MJG | по запросу |
Pin | 8 | 8 |
Package Type | JG | JG |
Industry STD Term | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 |
Carrier | TUBE | TUBE |
Маркировка | TLC7705 | MJG |
Width (мм) | 6.67 | 6.67 |
Length (мм) | 9.6 | 9.6 |
Thickness (мм) | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 |
# of Supplies Monitored | 1 |
Iq(Typ) | 9 uA |
Monitored Voltage 1 (typ)(Nom) | 5 В |
Output Driver Type / Reset Output | Active-high,Active-low,Push-pull |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Reset Threshold Accuracy | 1.8 % |
Threshold Voltage 1(Typ) | 4.55 В |
Threshold Voltage 2 (typ)(Typ) | N/A В |
Time Delay | Programmable ms |
VCC(Max) | 6 В |
VCC(Min) | 2 В |
Watchdog Timer WDI | None sec |
RoHS | See ti.com |
- TLC770x Series of BiCMOS Supply Voltage SupervisorsPDF, 327 Кб, Файл опубликован: 1 янв 1995
This report describes the function and application of the supply voltage supervisor circuit TLC770X. Besides a detailed functional description, the behavior of line and battery operated power supplies during power-up as well as the behavior of digital circuits is presented. Finally application-examples of supply voltage supervision in general and supply voltage supervision in systems are described - Reset Circuit for the TMS320C6000 DSP (Rev. A)PDF, 36 Кб, Версия: A, Файл опубликован: 10 июн 1999
This document describes two solutions used to provide a reset circuit to the Texas Instruments (TI)(tm) TMS320C6000 digital signal processor (DSP). One solution sets a supply voltage supervisor, such as the TI TLC7733 and TLC7725, on each of the supply voltages, DVdd and CVdd. Another solution monitors both the 2.5-V/1.8-V and 3.3-V power supplies using a single supervisor such as the TI TPS3707.
Серия: TLC7705M (7)
- Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
