Datasheet Texas Instruments TLC7733MFKB — Даташит
СерияTLC7733M
МодельTLC7733MFKB
Одиночный SVS для систем 3,3 В с программируемой задержкой времени 20-LCCC от -55 до 125
MicroPower Supply Voltage Supervisors. datasheet
PDF, 1.9 Мб, Версия: M, Файл опубликован: 19 мар 2012
Pin20202020
Package TypeFKFKFKFK
Industry STD TermLCCCLCCCLCCCLCCC
JEDEC CodeS-CQCC-NS-CQCC-NS-CQCC-NS-CQCC-N
Package QTY1111
CarrierTUBETUBETUBETUBE
Маркировка5962-9750901Q2AMFKBTLC7733
Width (мм)8.898.898.898.89
Length (мм)8.898.898.898.89
Thickness (мм)1.831.831.831.83
Pitch (мм)1.271.271.271.27
Max Height (мм)2.032.032.032.03
# of Supplies Monitored1
Iq(Typ)9 uA
Monitored Voltage 1 (typ)(Nom)3.3 В
Output Driver Type / Reset OutputActive-high,Active-low,Push-pull
Package GroupLCCC
Package Size: mm2:W x L20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG
RatingMilitary
Reset Threshold Accuracy2.4 %
Threshold Voltage 1(Typ)2.93 В
Threshold Voltage 2 (typ)(Typ)N/A В
Time DelayProgrammable ms
VCC(Max)6 В
VCC(Min)2 В
Watchdog Timer WDINone sec
RoHSSee ti.com
  • Reset Circuit for the TMS320C6000 DSP (Rev. A)
    PDF, 36 Кб, Версия: A, Файл опубликован: 10 июн 1999
    This document describes two solutions used to provide a reset circuit to the Texas Instruments (TI)(tm) TMS320C6000 digital signal processor (DSP). One solution sets a supply voltage supervisor, such as the TI TLC7733 and TLC7725, on each of the supply voltages, DVdd and CVdd. Another solution monitors both the 2.5-V/1.8-V and 3.3-V power supplies using a single supervisor such as the TI TPS3707.
  • Semiconductors > Space & High Reliability > Power Management Products > Supervisor and Reset ICs
На английском языке: Datasheet Texas Instruments TLC7733MFKB
