Datasheet Texas Instruments TLK100PHPR — Даташит
СерияTLK100
МодельTLK100PHPR
Промышленный Ethernet PHY 48-HTQFP от -40 до 85
Industrial Ethernet PHY datasheet
PDF, 1.4 Мб, Версия: B, Файл опубликован: 9 окт 2009
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
МаркировкаTLK100
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Cable Length200 m
Datarate10/100 Mbps
FunctionPHY
InterfaceMII
JTAG1149.1Yes
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
Port CountSingle
Special FeaturesCable Diagnostics
Напряжение питания3.3 Volt
  • Evaluation Modules & Boards: TLK100EXTEVM
    TLK100 External voltage EVM
  • TLK100 Ethernet PHY Transformerless Operation
    PDF, 1.4 Мб, Файл опубликован: 16 мар 2011
    The TLK100 is a single-port Ethernet PHY for 10BaseT and 100Base TX signaling. This application report describes a method for using Texas Instruments Ethernet PHY products without a transformer. A transformerless mode has great benefit in the following scenarios: nontypical applications that are sensitive to cost; short-distance, PCB connections (compromises cable reach); and industrial temperatur
Серия: TLK100 (2)
  • Semiconductors > Interface > Ethernet > Ethernet PHY
На английском языке: Datasheet Texas Instruments TLK100PHPR
