Datasheet Texas Instruments TLK1501IRCPR — Даташит
Серия | TLK1501 |
Модель | TLK1501IRCPR |
Трансивер 0,6–1,5 Гбит/с 64-HVQFP от -40 до 85
0.6 to 1.5 Gbps Transceiver datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 5 сен 2003
Pin | 64 |
Package Type | RCP |
Industry STD Term | HVQFP |
JEDEC Code | S-PQFP-G |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | TLK1501 |
Width (мм) | 10 |
Length (мм) | 10 |
Thickness (мм) | .8 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Package Group | HVQFP |
Package Size: mm2:W x L | 64HVQFP: 144 mm2: 12 x 12(HVQFP) PKG |
Rating | Catalog |
- Evaluation Modules & Boards: TLK1501EVM
TLK1501 SerDes Evaluation Module
- Using TI's CDCV304 w/Backplane Transceiver (TLK1201/1501/2201/2501/2701/3101) (Rev. A)PDF, 220 Кб, Версия: A, Файл опубликован: 20 апр 2006
- Using TI's CDCVF2310 and CDCVF25081 with TLK1501 Serial TransceiverPDF, 1.2 Мб, Файл опубликован: 14 май 2003
This test report discusses jitter transfer of the TI CDCVF2310 and CDCVF25081 clock drivers when driving the TI TLK1501 serial gigabit transceiver at 600 Mbit/sec. This application report summarizes the peak-to-peak and RMS jitter measurements taken during the testing of the clock drivers with the TLK1501. The CDCVF2310 is a high performance clock buffer that provides 10 low-skew copies of CLK at - Interfacing Between LVPECL, VML, CML and LVDS LevelsPDF, 253 Кб, Файл опубликован: 17 дек 2002
This application report introduces the various interface standards used today in modern telecom and datacom systems and describes the methods used to interface between similar and different I/O structures used on Texas Instruments serial gigabit solutions products. The main logic levels discussed in this application report are low-voltage positive/pseudo emitter-coupled logic (LVPECL), current-mo
Серия: TLK1501 (4)
- TLK1501IRCP TLK1501IRCPG4 TLK1501IRCPR TLK1501IRCPRG4
- Semiconductors > Interface > More Interfaces
