Datasheet Texas Instruments TLK1501IRCPG4 — Даташит
СерияTLK1501
МодельTLK1501IRCPG4
Трансивер 0,6–1,5 Гбит/с 64-HVQFP от -40 до 85
0.6 to 1.5 Gbps Transceiver datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 5 сен 2003
Pin64
Package TypeRCP
Industry STD TermHVQFP
JEDEC CodeS-PQFP-G
Package QTY160
CarrierJEDEC TRAY (10+1)
МаркировкаTLK1501
Width (мм)10
Length (мм)10
Thickness (мм).8
Pitch (мм).5
Max Height (мм)1
Package GroupHVQFP
Package Size: mm2:W x L64HVQFP: 144 mm2: 12 x 12(HVQFP) PKG
  • Evaluation Modules & Boards: TLK1501EVM
    TLK1501 SerDes Evaluation Module
  • Using TI's CDCV304 w/Backplane Transceiver (TLK1201/1501/2201/2501/2701/3101) (Rev. A)
    PDF, 220 Кб, Версия: A, Файл опубликован: 20 апр 2006
  • Using TI's CDCVF2310 and CDCVF25081 with TLK1501 Serial Transceiver
    PDF, 1.2 Мб, Файл опубликован: 14 май 2003
    This test report discusses jitter transfer of the TI CDCVF2310 and CDCVF25081 clock drivers when driving the TI TLK1501 serial gigabit transceiver at 600 Mbit/sec. This application report summarizes the peak-to-peak and RMS jitter measurements taken during the testing of the clock drivers with the TLK1501. The CDCVF2310 is a high performance clock buffer that provides 10 low-skew copies of CLK at
  • Interfacing Between LVPECL, VML, CML and LVDS Levels
    PDF, 253 Кб, Файл опубликован: 17 дек 2002
    This application report introduces the various interface standards used today in modern telecom and datacom systems and describes the methods used to interface between similar and different I/O structures used on Texas Instruments serial gigabit solutions products. The main logic levels discussed in this application report are low-voltage positive/pseudo emitter-coupled logic (LVPECL), current-mo
Серия: TLK1501 (4)
  • Semiconductors > Interface > More Interfaces
На английском языке: Datasheet Texas Instruments TLK1501IRCPG4
