Datasheet Texas Instruments TLK6002ZEU — Даташит
Серия | TLK6002 |
Модель | TLK6002ZEU |
Двухканальный многоскоростной трансивер 0,47–6,25 Гбит/с 324-BGA от -40 до 85
Dual Channel 0.47Gbps to 6.25Gbps Multi-Rate Transceiver datasheet
PDF, 850 Кб, Версия: A, Файл опубликован: 5 сен 2010
Pin | 324 |
Package Type | ZEU |
Industry STD Term | BGA |
JEDEC Code | S-PBGA-N |
Package QTY | 84 |
Carrier | JEDEC TRAY (10+1) |
Маркировка | TLK6002 |
Width (мм) | 19 |
Length (мм) | 19 |
Thickness (мм) | 1.73 |
Pitch (мм) | 1 |
Max Height (мм) | 2.42 |
Mechanical Data | Скачать |
Package Group | BGA |
Package Size: mm2:W x L | 324BGA: 361 mm2: 19 x 19(BGA) PKG |
Rating | Catalog |
- High-Speed Gigabit Data Transmission Across Various Cable MediaPDF, 3.6 Мб, Файл опубликован: 8 ноя 2000
This application report focuses on characteristics of gigabit signals across different cable media, transmission distance and data rate. The signal quality of four different cables is evaluated using eye measurements and TI?s TLK2500 evaluation modules (EVMs). This document provides guidance for cable selection to use with Texas Instruments line of gigabit parts. - TLK6002 Board Design GuidelinesPDF, 179 Кб, Файл опубликован: 19 окт 2010
The TLK6002 is a multi-gigabit transceiver intended for use in ultra-high-speed, bidirectional, point-to-point, data transmission systems such as base station Remote Radio Head (RRH) applications as well as any other high-speed applications. All CPRI and OBSAI data rates of 0.6144, 0.768, 1.2288, 1.536, 2.4576, 3.072, 4.9152, and 6.144Gbps are supported using a single, fixed reference clock freque - Interfacing Between LVPECL, VML, CML and LVDS LevelsPDF, 253 Кб, Файл опубликован: 17 дек 2002
This application report introduces the various interface standards used today in modern telecom and datacom systems and describes the methods used to interface between similar and different I/O structures used on Texas Instruments serial gigabit solutions products. The main logic levels discussed in this application report are low-voltage positive/pseudo emitter-coupled logic (LVPECL), current-mo
Серия: TLK6002 (1)
- TLK6002ZEU
- Semiconductors > Interface > More Interfaces
