Datasheet Texas Instruments TLV320ADC3001IYZHR — Даташит
Серия | TLV320ADC3001 |
Модель | TLV320ADC3001IYZHR |
Маломощный стерео АЦП с соотношением сигнал/шум 92 дБ (ADC3001) 16-DSBGA от -40 до 85
TLV320ADC3001 Low-Power Stereo ADC With Embedded miniDSP for Wireless Handsets and Portable Audio datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 31 авг 2015
Pin | 16 |
Package Type | YZH |
Industry STD Term | DSBGA |
JEDEC Code | S-XBGA-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | ADC3001 |
Thickness (мм) | .48 |
Pitch (мм) | .5 |
Max Height (мм) | .625 |
Mechanical Data | Скачать |
ADC Channels | 2 |
ADC SNR(Typ) | 92 дБ |
Additional Features | Low-latency IIR linear-phase FIR filters,Analog Mic support |
Analog Inputs | 3 |
Control Interface | I2C |
Digital Audio Interface | L,R,I2S,DSP,TDM,PCM |
Package Size: mm2:W x L | See datasheet (DSBGA) PKG |
Sampling Rate(Max) | 96 kHz |
- Coefficient RAM Access Mechanisms.. (Rev. D)PDF, 140 Кб, Версия: D, Файл опубликован: 25 янв 2012
- Interfacing an I2S Device to an MSP430 Device (Rev. A)PDF, 72 Кб, Версия: A, Файл опубликован: 22 мар 2010
The MSP430 series of microprocessors are fast powerful devices ideally suited for use with the various wireless transceivers offered by Texas Instruments. In streaming audio applications, however, it is desirable that the microprocessor support an audio bus to allow for interconnection to an audio CODEC. This application note describes how to create an I2S-like bus (left-justified mode) from an SP - Audio Serial Interface Configurations for Audio CodecsPDF, 70 Кб, Файл опубликован: 22 сен 2010
An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
Серия: TLV320ADC3001 (2)
- TLV320ADC3001IYZHR TLV320ADC3001IYZHT
- Semiconductors > Audio > Audio Converters > Audio ADC
