Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TLV320ADC3001IYZHT — Даташит
СерияTLV320ADC3001
МодельTLV320ADC3001IYZHT
Маломощный стерео АЦП с соотношением сигнал/шум 92 дБ (ADC3001) 16-DSBGA от -40 до 85
TLV320ADC3001 Low-Power Stereo ADC With Embedded miniDSP for Wireless Handsets and Portable Audio datasheet
PDF, 1.4 Мб, Версия: D, Файл опубликован: 31 авг 2015
Pin16
Package TypeYZH
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаADC3001
Thickness (мм).48
Pitch (мм).5
Max Height (мм).625
ADC Channels2
ADC SNR(Typ)92 дБ
Additional FeaturesLow-latency IIR linear-phase FIR filters,Analog Mic support
Analog Inputs3
Control InterfaceI2C
Digital Audio InterfaceL,R,I2S,DSP,TDM,PCM
Sampling Rate(Max)96 kHz
  • Coefficient RAM Access Mechanisms.. (Rev. D)
    PDF, 140 Кб, Версия: D, Файл опубликован: 25 янв 2012
  • Interfacing an I2S Device to an MSP430 Device (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 22 мар 2010
    The MSP430 series of microprocessors are fast powerful devices ideally suited for use with the various wireless transceivers offered by Texas Instruments. In streaming audio applications, however, it is desirable that the microprocessor support an audio bus to allow for interconnection to an audio CODEC. This application note describes how to create an I2S-like bus (left-justified mode) from an SP
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
Серия: TLV320ADC3001 (2)
  • Semiconductors > Audio > Audio Converters > Audio ADC
На английском языке: Datasheet Texas Instruments TLV320ADC3001IYZHT
