Datasheet Texas Instruments TLV320AIC1110PBSG4 — Даташит
| Серия | TLV320AIC1110 |
| Модель | TLV320AIC1110PBSG4 |
Программируемый PCM-кодек с микрофонными усилителями и динамиком 32-TQFP от -40 до 85
Купить TLV320AIC1110PBSG4 на РадиоЛоцман.Цены — от 134 до 543 ₽8 предложений от 8 поставщиков Кодек, Audio Codec 1ADC / 1DAC 15Bit 32Pin TQFP Tray | |||
| TLV320AIC1110PBSG4 Texas Instruments | 134 ₽ | ||
| TLV320AIC1110PBSG4 Texas Instruments | 269 ₽ | ||
| TLV320AIC1110PBSG4 Texas Instruments | 337 ₽ | ||
| TLV320AIC1110PBSG4 Texas Instruments | по запросу | ||
| Pin | 32 |
| Package Type | PBS |
| Industry STD Term | TQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 250 |
| Carrier | JEDEC TRAY (10+1) |
| Маркировка | AIC1110 |
| Width (мм) | 5 |
| Length (мм) | 5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| ADC Channels | 1 |
| Analog Inputs | 2 |
| Analog Outputs | 2 |
| DAC Channels | 1 |
| Digital Audio Interface | PCM |
| Package Size: mm2:W x L | 80BGA MICROSTAR JUNIOR: 25 mm2: 5 x 5(BGA MICROSTAR JUNIOR),32TQFP: 49 mm2: 7 x 7(TQFP) PKG |
| Sampling Rate(Max) | 8 kHz |
- Interface the TLV320AIC1110 CODEC With The TMS320C5402 DSPPDF, 140 Кб, Файл опубликован: 7 ноя 2002
The TLV320AIC1110 is one of the high-performance codecs from Texas Instruments (TI) designed for easy use in various voice-band communication applications. It is an enhanced codec with more control capabilities. This application report provides the user with a simple coding example that facilitates the interface of this codec with the TMS320C5402в„ў DSP. The example code provides a good bas - Interface With Voice-Band Codecs Using I2CPDF, 231 Кб, Файл опубликован: 19 мар 2003
This application report builds up an I2C port from two pins in a McBSP, develops the I2C software driver, and interfaces with the voice-band codec(s), including TLV320AIC1103/1109 /1110, TLV320AIC12/ 13/ 14/ 15, or TLV320AIC20/ 21/ 24/ 25 devices. The I2C driverdesign is discussed in details and the corresponding C code is presented. - TLV320AIC12/13/14/15 CODEC Operating Under Stand-Alone Slave ModePDF, 212 Кб, Файл опубликован: 16 май 2002
This application report presents the methods, tips, and examples for using the TLV320AIC12/13/14/15 codec in stand-alone slave mode. The TMS320C5402 DSK and the Code Composer Studio? (CCS) were used as the development platform for this DSP-codec system. - Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 CodecsPDF, 103 Кб, Файл опубликован: 30 апр 2003
This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs. - Getting Started with the TLV320AIC3x Configuration ToolPDF, 1.1 Мб, Файл опубликован: 19 авг 2006
This application note helps users to begin working with the TLV320AIC3x Configuration Tool. Using easy-to-understand graphics, this report shows how to generate a configuration for the complex audio codecs TLV320AIC31, TLV320AIC32 or TLV320AIC33 based on user-defined settings. Additionally, interface software (available for download with this document) for the TMS320C5500 and TMS320C6000 familie - How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PCPDF, 480 Кб, Файл опубликован: 14 дек 2004
Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1. - Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
- Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP PortPDF, 105 Кб, Файл опубликован: 8 июл 2009
This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications - Out-of-Band Noise Measurement Issues for Audio CodecsPDF, 145 Кб, Файл опубликован: 6 дек 2006
- Audio Serial Interface Configurations for Audio CodecsPDF, 70 Кб, Файл опубликован: 22 сен 2010
An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock - Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECsPDF, 291 Кб, Файл опубликован: 27 сен 2000
This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies. - Control Port And Reset Operation SoundPlus Audio Converters and CODECsPDF, 77 Кб, Файл опубликован: 27 сен 2000
This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter. - Solving Enumeration Errors in USB Audio DAC and CODEC DesignsPDF, 157 Кб, Файл опубликован: 30 окт 2009
TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
Серия: TLV320AIC1110 (4)
- TLV320AIC1110PBS TLV320AIC1110PBSG4 TLV320AIC1110PBSR TLV320AIC1110ZQER
- Semiconductors > Audio > Audio Converters > Audio CODEC
