Datasheet Texas Instruments TLV32012KIDBTRG4 — Даташит
СерияTLV320AIC12K
МодельTLV32012KIDBTRG4
Маломощный монокодек голосового диапазона с усилителем динамика 8 Ом 30-TSSOP от -40 до 85
Low Power Highly-Integrated Programmable 16-Bit 26-KSPS Mono CODEC datasheet
PDF, 1.6 Мб, Версия: E, Файл опубликован: 19 янв 2007
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY2000
Маркировка320AIC12KI
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
ADC Channels1
ADC SNR(Typ)84 дБ
Analog Inputs3
Analog Outputs3
DAC Channels1
DAC SNR(Typ)92 дБ
Digital Audio InterfaceDSP,SMART TDM
Package Size: mm2:W x L30TSSOP: 50 mm2: 6.4 x 7.8(TSSOP),32VQFN: 25 mm2: 5 x 5(VQFN) PKG
Sampling Rate(Max)26 kHz
  • Evaluation Modules & Boards: TLV320AIC12KEVMB-K
    TLV320AIC12K Evaluation Module (EVM) and USB motherboard
  • TLV320AIC12/13/14/15 CODEC Operating Under Stand-Alone Slave Mode
    PDF, 212 Кб, Файл опубликован: 16 май 2002
    This application report presents the methods, tips, and examples for using the TLV320AIC12/13/14/15 codec in stand-alone slave mode. The TMS320C5402 DSK and the Code Composer Studio? (CCS) were used as the development platform for this DSP-codec system.
  • Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 Codecs
    PDF, 103 Кб, Файл опубликован: 30 апр 2003
    This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs.
  • Getting Started with the TLV320AIC3x Configuration Tool
    PDF, 1.1 Мб, Файл опубликован: 19 авг 2006
    This application note helps users to begin working with the TLV320AIC3x Configuration Tool. Using easy-to-understand graphics, this report shows how to generate a configuration for the complex audio codecs TLV320AIC31, TLV320AIC32 or TLV320AIC33 based on user-defined settings. Additionally, interface software (available for download with this document) for the TMS320C5500 and TMS320C6000 familie
  • How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PC
    PDF, 480 Кб, Файл опубликован: 14 дек 2004
    Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1.
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLV32012KIDBTRG4
