Datasheet Texas Instruments TLV320AIC13IDBT — Даташит
Серия | TLV320AIC13 |
Модель | TLV320AIC13IDBT |
Маломощный монофонический голосовой диапазон CODEC 30-TSSOP от -40 до 85
SMARTDM? Low Power, Low-Voltage, 1.1-V to 3.6-V I/O, 16-Bit, 26-KSPS Codec datasheet
PDF, 380 Кб, Версия: A, Файл опубликован: 3 май 2002
Статус продукта | NRND (Не рекомендуется для новых разработок) |
Pin | 30 |
Package Type | DBT |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 60 |
Carrier | TUBE |
Маркировка | 320AIC13I |
Width (мм) | 4.4 |
Length (мм) | 7.8 |
Thickness (мм) | 1 |
Pitch (мм) | .5 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
- Interfacing the TLV320AIC12/13/14/15 Codec to the TMS320C5402? DSPPDF, 156 Кб, Файл опубликован: 24 окт 2002
This application report presents the process of interfacing of the TLV320AIC12/13/14/15 voice-band codec with the TMS320C5402? DSP. It presents the hardware configuration and the software driver for a two-device cascade (single master and single slave) configuration mode. The design can be considered as an application example, a test tool, or a startup platform for developing and using the codec - Interface With Voice-Band Codecs Using I2CPDF, 231 Кб, Файл опубликован: 19 мар 2003
This application report builds up an I2C port from two pins in a McBSP, develops the I2C software driver, and interfaces with the voice-band codec(s), including TLV320AIC1103/1109 /1110, TLV320AIC12/ 13/ 14/ 15, or TLV320AIC20/ 21/ 24/ 25 devices. The I2C driverdesign is discussed in details and the corresponding C code is presented. - TLV320AIC12/13/14/15 CODEC Operating Under Stand-Alone Slave ModePDF, 212 Кб, Файл опубликован: 16 май 2002
This application report presents the methods, tips, and examples for using the TLV320AIC12/13/14/15 codec in stand-alone slave mode. The TMS320C5402 DSK and the Code Composer Studio? (CCS) were used as the development platform for this DSP-codec system. - Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 CodecsPDF, 103 Кб, Файл опубликован: 30 апр 2003
This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs.
Серия: TLV320AIC13 (2)
- TLV320AIC13IDBT TLV320AIC13IDBTG4
- Semiconductors > Audio > Audio Converters > Audio CODEC
