Datasheet Texas Instruments TLV320AIC15IDBT — Даташит
СерияTLV320AIC15
МодельTLV320AIC15IDBT
Маломощный монофонический голосовой диапазон CODEC 30-TSSOP от -40 до 85
SMARTDM? Low Power, Low Voltage, 1.1-V to 3.6-V I/O 16-Bit, 26-KSPS Codec datasheet
PDF, 366 Кб, Версия: A, Файл опубликован: 3 май 2002
Pin30
Package TypeDBT
Industry STD TermTSSOP
Package QTY60
Маркировка320AIC15I
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
  • Interfacing the TLV320AIC12/13/14/15 Codec to the TMS320C5402? DSP
    PDF, 156 Кб, Файл опубликован: 24 окт 2002
    This application report presents the process of interfacing of the TLV320AIC12/13/14/15 voice-band codec with the TMS320C5402? DSP. It presents the hardware configuration and the software driver for a two-device cascade (single master and single slave) configuration mode. The design can be considered as an application example, a test tool, or a startup platform for developing and using the codec
  • Interface With Voice-Band Codecs Using I2C
    PDF, 231 Кб, Файл опубликован: 19 мар 2003
    This application report builds up an I2C port from two pins in a McBSP, develops the I2C software driver, and interfaces with the voice-band codec(s), including TLV320AIC1103/1109 /1110, TLV320AIC12/ 13/ 14/ 15, or TLV320AIC20/ 21/ 24/ 25 devices. The I2C driverdesign is discussed in details and the corresponding C code is presented.
  • TLV320AIC12/13/14/15 CODEC Operating Under Stand-Alone Slave Mode
    PDF, 212 Кб, Файл опубликован: 16 май 2002
    This application report presents the methods, tips, and examples for using the TLV320AIC12/13/14/15 codec in stand-alone slave mode. The TMS320C5402 DSK and the Code Composer Studio? (CCS) were used as the development platform for this DSP-codec system.
  • Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 Codecs
    PDF, 103 Кб, Файл опубликован: 30 апр 2003
    This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs.
Серия: TLV320AIC15 (2)
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLV320AIC15IDBT
