Datasheet Texas Instruments TLV320AIC20IPFBR — Даташит
| Серия | TLV320AIC20 |
| Модель | TLV320AIC20IPFBR |
Маломощный стереофонический голосовой диапазон CODEC 48-TQFP от -40 до 85
Low Power Highly-Integrated Programmable 16-Bit 26-KSPS Dual Channel CODEC datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 12 апр 2005
Купить TLV320AIC20IPFBR на РадиоЛоцман.Цены — от 267 до 2 734 ₽15 предложений от 15 поставщиков IC CODEC 16BIT DUAL PROG 48-TQFP. Voice-Band Interface 16 b Serial 48-TQFP (7x7). Interface - CODECs | |||
| TLV320AIC20IPFBR Texas Instruments | 493 ₽ | ||
| TLV320AIC20IPFBR Texas Instruments | 562 ₽ | ||
| TLV320AIC20IPFBR Texas Instruments | 1 085 ₽ | ||
| TLV320AIC20IPFBR Texas Instruments | 1 159 ₽ | ||
| Статус продукта | NRND (Не рекомендуется для новых разработок) |
| Pin | 48 |
| Package Type | PFB |
| Industry STD Term | TQFP |
| JEDEC Code | S-PQFP-G |
| Package QTY | 1000 |
| Carrier | LARGE T&R |
| Маркировка | 320AIC20I |
| Width (мм) | 7 |
| Length (мм) | 7 |
| Thickness (мм) | 1 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
- TMS320C54x DSP Reference Framework & Device Driver for the TLV320AIC20 HPA DCPDF, 692 Кб, Файл опубликован: 16 янв 2003
The TLV320AIC20 is a high performance analog (HPA) data converter geared for voiceband digital applications (typically 8-kHz sampling rates.) The TLV320AIC20EVM is an evaluation module that connects to a TI DSP starter kit (DSK) via a standard AIC motherboard (Part no. AICDEVPLATEVM). The EVM contains two AIC20 dual-codec devices connected in a cascaded configuration, allowing the user to config - Demo/Test CODEC System with TLV320AIC20/21/24/25 EVMPDF, 141 Кб, Файл опубликован: 26 авг 2002
A demo/test system has been built as a simple example for using the TLV320AIC20/21/24/25 codecs. The hardware part of the system includes the ?AIC20/21/24/25 EVM boards, an AIC development interface board, and a TMS320C5402 DSP DSK board. The C54xx software, in assembly and C, is implemented on the ?C5402 DSP. A 2-device, 4-channel and a 6-device, 12-channel codec system are presented in this appl - Interface With Voice-Band Codecs Using I2CPDF, 231 Кб, Файл опубликован: 19 мар 2003
This application report builds up an I2C port from two pins in a McBSP, develops the I2C software driver, and interfaces with the voice-band codec(s), including TLV320AIC1103/1109 /1110, TLV320AIC12/ 13/ 14/ 15, or TLV320AIC20/ 21/ 24/ 25 devices. The I2C driverdesign is discussed in details and the corresponding C code is presented. - Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 CodecsPDF, 103 Кб, Файл опубликован: 30 апр 2003
This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs.
Серия: TLV320AIC20 (6)
- TLV320AIC20CPFB TLV320AIC20CPFBG4 TLV320AIC20IPFB TLV320AIC20IPFBG4 TLV320AIC20IPFBR TLV320AIC20IPFBRG4
- Semiconductors > Audio > Audio Converters > Audio CODEC
