Datasheet Texas Instruments TLV320AIC23BRHDR — Даташит
| Серия | TLV320AIC23B |
| Модель | TLV320AIC23BRHDR |
Маломощный стереокодек с усилителем HP 28-VQFN от 0 до 70
Stereo Audio CODEC, 8-to 96-KHz, With Integrated Headphone Amplifier datasheet
PDF, 1.1 Мб, Версия: H, Файл опубликован: 12 фев 2004
Купить TLV320AIC23BRHDR на РадиоЛоцман.Цены — от 78 до 1 063 ₽20 предложений от 18 поставщиков IC STEREO AUDIO CODEC 28VQFN. Stereo Audio Interface 16 b, 20 b, 24 b, 32 b I²C, Serial 28-VQFN (5x5). Interface... | |||
| TLV320AIC23BRHDR Texas Instruments | 78 ₽ | ||
| TLV320AIC23BRHDR Texas Instruments | 117 ₽ | ||
| TLV320AIC23BRHDR Texas Instruments | 434 ₽ | ||
| TLV320AIC23BRHDR Texas Instruments | 577 ₽ | ||
| Pin | 28 |
| Package Type | RHD |
| Industry STD Term | VQFN |
| JEDEC Code | S-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | AIC23B |
| Width (мм) | 5 |
| Length (мм) | 5 |
| Thickness (мм) | .9 |
| Pitch (мм) | .5 |
| Max Height (мм) | 1 |
| Mechanical Data | Скачать |
| ADC Channels | 1 |
| ADC SNR(Typ) | 90 дБ |
| Analog Inputs | 3 |
| Analog Outputs | 4 |
| DAC Channels | 1 |
| DAC SNR(Typ) | 100 дБ |
| Digital Audio Interface | L,R,I2S,DSP |
| Package Size: mm2:W x L | 80BGA MICROSTAR JUNIOR: 25 mm2: 5 x 5(BGA MICROSTAR JUNIOR),28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP),28VQFN: 25 mm2: 5 x 5(VQFN) PKG |
| Sampling Rate(Max) | 96 kHz |
- Evaluation Modules & Boards: TLV320AIC23EVM2
TLV320AIC23 Evaluation Module (EVM)
- Dynamic Behavior of TLV320DAC23 and TLV320AIC23BPDF, 451 Кб, Файл опубликован: 16 июн 2004
- TLV320AIC12/13/14/15 CODEC Operating Under Stand-Alone Slave ModePDF, 212 Кб, Файл опубликован: 16 май 2002
This application report presents the methods, tips, and examples for using the TLV320AIC12/13/14/15 codec in stand-alone slave mode. The TMS320C5402 DSK and the Code Composer Studio? (CCS) were used as the development platform for this DSP-codec system. - Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 CodecsPDF, 103 Кб, Файл опубликован: 30 апр 2003
This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs. - How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PCPDF, 480 Кб, Файл опубликован: 14 дек 2004
Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1. - Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
- Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP PortPDF, 105 Кб, Файл опубликован: 8 июл 2009
This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications - Out-of-Band Noise Measurement Issues for Audio CodecsPDF, 145 Кб, Файл опубликован: 6 дек 2006
- Audio Serial Interface Configurations for Audio CodecsPDF, 70 Кб, Файл опубликован: 22 сен 2010
An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock - Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECsPDF, 291 Кб, Файл опубликован: 27 сен 2000
This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies. - Control Port And Reset Operation SoundPlus Audio Converters and CODECsPDF, 77 Кб, Файл опубликован: 27 сен 2000
This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter. - Solving Enumeration Errors in USB Audio DAC and CODEC DesignsPDF, 157 Кб, Файл опубликован: 30 окт 2009
TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
Серия: TLV320AIC23B (20)
- TLV320AIC23BGQE TLV320AIC23BIGQE TLV320AIC23BIPW TLV320AIC23BIPWG4 TLV320AIC23BIPWR TLV320AIC23BIPWRG4 TLV320AIC23BIRHD TLV320AIC23BIRHDG4 TLV320AIC23BIRHDR TLV320AIC23BIZQE TLV320AIC23BPW TLV320AIC23BPWG4 TLV320AIC23BPWR TLV320AIC23BPWRG4 TLV320AIC23BRHD TLV320AIC23BRHDG4 TLV320AIC23BRHDR TLV320AIC23BRHDRG4 TLV320AIC23BZQE TLV320AIC23BZQER
- Semiconductors > Audio > Audio Converters > Audio CODEC
