Datasheet Texas Instruments TLV320AIC24CPFBR — Даташит
СерияTLV320AIC24
МодельTLV320AIC24CPFBR
Маломощный стереофонический голосовой диапазон CODEC 48-TQFP от 0 до 70
Low Power Highly-Integrated Programmable 16-Bit 26-KSPS Dual Channel CODEC datasheet
PDF, 1.6 Мб, Версия: D, Файл опубликован: 12 апр 2005
Pin48
Package TypePFB
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY1000
Маркировка320AIC24C
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Рекомендуемая замена
ReplacementTLV320AIC24KIPFBR
Replacement CodeF
  • TMS320C54xx McBSP to TLV320AIC24 Interface
    PDF, 272 Кб, Файл опубликован: 30 сен 2003
    This application note describes a method for interfacing the TMS320C5400 multichannel buffer serial ports (McBSP) to the TLV320AIC24.The TLV320AIC24 innovation is the smart-time division, multiplexed serial port (SMARTDMв„ў) that optimizes the DSP performance with an advanced synchronous 4-wire serial port in TDM format for glue-free interface to popular DSPs (i.e., C5000, C6000) and mi
  • Hands-Free Kit: Integration of the AIC24 Driver in RF3
    PDF, 323 Кб, Файл опубликован: 18 дек 2003
  • Demo/Test CODEC System with TLV320AIC20/21/24/25 EVM
    PDF, 141 Кб, Файл опубликован: 26 авг 2002
    A demo/test system has been built as a simple example for using the TLV320AIC20/21/24/25 codecs. The hardware part of the system includes the ?AIC20/21/24/25 EVM boards, an AIC development interface board, and a TMS320C5402 DSP DSK board. The C54xx software, in assembly and C, is implemented on the ?C5402 DSP. A 2-device, 4-channel and a 6-device, 12-channel codec system are presented in this appl
  • Interface With Voice-Band Codecs Using I2C
    PDF, 231 Кб, Файл опубликован: 19 мар 2003
    This application report builds up an I2C port from two pins in a McBSP, develops the I2C software driver, and interfaces with the voice-band codec(s), including TLV320AIC1103/1109 /1110, TLV320AIC12/ 13/ 14/ 15, or TLV320AIC20/ 21/ 24/ 25 devices. The I2C driverdesign is discussed in details and the corresponding C code is presented.
  • Common Sample Rate Selection For TLV320AIC12/13/14/15/20/21/24/25 Codecs
    PDF, 103 Кб, Файл опубликован: 30 апр 2003
    This application report intends to help TI voice-band codec users to quickly and properly select the commonly used master clock frequency (MCLK) and the corresponding frequency dividers, M, N, and P, which is the first step For utilizing TI?s TLV320AIC12 /13 /14 /15 /20 /21 /24 /25 voice-band codecs.
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLV320AIC24CPFBR
