Datasheet Texas Instruments TLV320AIC3106IRGZT — Даташит
СерияTLV320AIC3106
МодельTLV320AIC3106IRGZT
Маломощный стереокодек с 10 входами, 7 выходами, усилителем HP и улучшенными цифровыми эффектами 48-VQFN от -40 до 85
TLV320AIC3106 Low-Power Stereo Audio CODEC for Portable Audio/Telephony datasheet
PDF, 2.8 Мб, Версия: F, Файл опубликован: 24 дек 2014
Pin48
Package TypeRGZ
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаAC3106I
Width (мм)7
Length (мм)7
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
ADC Channels2
ADC SNR(Typ)92 дБ
Analog Inputs10
Analog Outputs7
DAC Channels2
DAC SNR(Typ)102 дБ
Digital Audio InterfaceL,R,I2S,DSP,TDM
Package Size: mm2:W x L80BGA MICROSTAR JUNIOR: 25 mm2: 5 x 5(BGA MICROSTAR JUNIOR),48VQFN: 49 mm2: 7 x 7(VQFN) PKG
Sampling Rate(Max)96 kHz
  • Evaluation Modules & Boards: TLV320AIC3106EVM-K
    TLV320AIC3106 Evaluation Module and USB Motherboard
  • Evaluation Modules & Boards: EVMX777BG-01-00-00
    J6Entry, RSP and TDA2E-17 CPU Board Evaluation Module
  • Evaluation Modules & Boards: TMDXEVM388
    DM388 DaVinci Digital Media Processor Evaluation Module
  • Evaluation Modules & Boards: EVMK2G
    66AK2Gx (K2G) Evaluation Module
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Headset Detection for TLV320AIC33 and TLV320AIC310x Family
    PDF, 191 Кб, Файл опубликован: 22 июн 2010
    A common feature in most of today's electronic devices – including cell phone, PDAs, notebooks, handheld media players, game systems, etc. – is the provision for connecting to external accessories. The devices therefore include dedicated logic circuitry that can detect not only the presence of an accessory, but also its type.The TLV320AIC33 and TLV320AIC3101/4/5/6 family includes extensive ca
  • Common Noise Issues in Audio Codecs
    PDF, 110 Кб, Файл опубликован: 21 июл 2017
    This application note describes methods that can be used to improve noise performance in systems usingaudio codecs. Noise is present in all circuit board systems; however, common design practices can helpminimize overall noise contribution to improve the audio quality using audio codecs. Recommendations inthis document apply to the TLV320AICxxxx, TLV320ADCxxxx, and TLV320DACxxxx audio conver
  • Interfacing an I2S Device to an MSP430 Device (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 22 мар 2010
    The MSP430 series of microprocessors are fast powerful devices ideally suited for use with the various wireless transceivers offered by Texas Instruments. In streaming audio applications, however, it is desirable that the microprocessor support an audio bus to allow for interconnection to an audio CODEC. This application note describes how to create an I2S-like bus (left-justified mode) from an SP
  • Getting Started with the TLV320AIC3x Configuration Tool
    PDF, 1.1 Мб, Файл опубликован: 19 авг 2006
    This application note helps users to begin working with the TLV320AIC3x Configuration Tool. Using easy-to-understand graphics, this report shows how to generate a configuration for the complex audio codecs TLV320AIC31, TLV320AIC32 or TLV320AIC33 based on user-defined settings. Additionally, interface software (available for download with this document) for the TMS320C5500 and TMS320C6000 familie
  • How to Set the TSC/AIC EVM to Record & Playback Audio or Other Sound Through PC
    PDF, 480 Кб, Файл опубликован: 14 дек 2004
    Record and playback audio, sound, or voice on a TI touch screen controller (TSC) or audio codec (AIC) EVM system by means of the associated software running on a PC system. The PC and EVM are connected using a USB cable. This application report gives an example to demonstrate how to do this through a Windows XP? PC system. The block diagram and connection are shown in Figure 1.
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLV320AIC3106IRGZT
