Datasheet Texas Instruments TLV320AIC34IZAS — Даташит
СерияTLV320AIC34
МодельTLV320AIC34IZAS
Четырехканальный кодек с низким энергопотреблением 87-NFBGA от -40 до 85
TLV320AIC34 Four-Channel, Low-Power Audio Codec for Portable Audio and Telephony datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 29 ноя 2016
Pin87
Package TypeZAS
Industry STD TermNFBGA
JEDEC CodeS-PBGA-N
Package QTY250
CarrierJEDEC TRAY (5+1)
МаркировкаTAIC34I
Width (мм)6
Length (мм)6
Thickness (мм).89
Pitch (мм).5
Max Height (мм)1.2
ADC Channels4
ADC SNR(Typ)92 дБ
Analog Inputs12
Analog Outputs14
DAC Channels4
DAC SNR(Typ)100 дБ
Digital Audio InterfaceL,R,I2S,DSP
Package Size: mm2:W x L87NFBGA: 36 mm2: 6 x 6(NFBGA) PKG
Sampling Rate(Max)96 kHz
  • Evaluation Modules & Boards: TLV320AIC34EVM-K
    TLV320AIC34 Evaluation Module (EVM) and USB motherboard
  • Common Noise Issues in Audio Codecs
    PDF, 110 Кб, Файл опубликован: 21 июл 2017
    This application note describes methods that can be used to improve noise performance in systems usingaudio codecs. Noise is present in all circuit board systems; however, common design practices can helpminimize overall noise contribution to improve the audio quality using audio codecs. Recommendations inthis document apply to the TLV320AICxxxx, TLV320ADCxxxx, and TLV320DACxxxx audio conver
  • Getting Started with the TLV320AIC3x Configuration Tool
    PDF, 1.1 Мб, Файл опубликован: 19 авг 2006
    This application note helps users to begin working with the TLV320AIC3x Configuration Tool. Using easy-to-understand graphics, this report shows how to generate a configuration for the complex audio codecs TLV320AIC31, TLV320AIC32 or TLV320AIC33 based on user-defined settings. Additionally, interface software (available for download with this document) for the TMS320C5500 and TMS320C6000 familie
  • Using the MSP430 Launchpad as a Standalone I2C Host for Audio Products (Rev. A)
    PDF, 5.4 Мб, Версия: A, Файл опубликован: 28 окт 2013
  • Configuring I2S to Generate BCLK from Codec Devices & WCLK from McBSP Port
    PDF, 105 Кб, Файл опубликован: 8 июл 2009
    This application note describes a method for interfacing the multichannel buffered serial port (McBSP) to the IВІSв„ў interface of the TLV320AIC32/33/31, theTLV320AIC3101/3104/3105/3106/3204/3254 and TLV320DAC32 devices such that the bit clock (BCLK) is generated by the audio data converter device and the word clock (WCLK) is generated by the McBSP.This type of interface is useful in applications
  • Out-of-Band Noise Measurement Issues for Audio Codecs
    PDF, 145 Кб, Файл опубликован: 6 дек 2006
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
  • Low Sampling Rate Operation SoundPlus Audio Data Converters and CODECs
    PDF, 291 Кб, Файл опубликован: 27 сен 2000
    This application bulletin describes the operation and performance of Burr-Brown's PCM digital audio products when using low sampling frequencies.
  • Control Port And Reset Operation SoundPlus Audio Converters and CODECs
    PDF, 77 Кб, Файл опубликован: 27 сен 2000
    This application bulletin provides operational details of the serial control port and reset functions for Burr-Brown digital audio data converters and CODECs. Specifically, this information applies to the PCM1716, PCM1717, PCM1719, PCM1720, PCM1723, PCM1727, PCM3000-series CODECs, and the PCM1800 A/D converter.
  • Solving Enumeration Errors in USB Audio DAC and CODEC Designs
    PDF, 157 Кб, Файл опубликован: 30 окт 2009
    TI’s portfolio of audio digital-to-analog converters (DACs) and coder/decoders (codecs) with integrated USB interfaces offers an excellent building block for any streaming USB audio system. When designing with the PCM270x and PCM29xx devices, careful attention must be given to both the clocking and USB hardware configurations in order to ensure proper host to device communication.This applicatio
Серия: TLV320AIC34 (2)
  • Semiconductors > Audio > Audio Converters > Audio CODEC
На английском языке: Datasheet Texas Instruments TLV320AIC34IZAS
