Datasheet Texas Instruments TLV320DAC3101IRHBR — Даташит
Серия | TLV320DAC3101 |
Модель | TLV320DAC3101IRHBR |
Маломощный стереоаудио ЦАП с усилителем стереодинамиков класса D 32-VQFN от -40 до 85
Low-Power Stereo Audio DAC With Stereo Class-D Speaker Amplifier datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 1 май 2012
Pin | 32 |
Package Type | RHB |
Industry STD Term | VQFN |
JEDEC Code | S-PQFP-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | DAC3101 |
Width (мм) | 5 |
Length (мм) | 5 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Analog Inputs | 2 |
Analog Outputs | 4 |
Архитектура | Class D |
Control Interface | I2C |
DAC Channels | 2 |
DAC SNR(Typ) | 95 дБ |
Package Size: mm2:W x L | 32VQFN: 25 mm2: 5 x 5(VQFN) PKG |
Разрешение | 32 Bits |
Sampling Rate(Max) | 192 kHz |
- Evaluation Modules & Boards: TLV320DAC3101EVM-U
TLV320DAC3101EVM-U Evaluation Module
- TLV320AIC31xx and TLV320DAC31xx Power Consumption Characterization (Rev. B)PDF, 136 Кб, Версия: B, Файл опубликован: 3 сен 2014
- Coefficient RAM Access Mechanisms.. (Rev. D)PDF, 140 Кб, Версия: D, Файл опубликован: 25 янв 2012
- Interfacing an I2S Device to an MSP430 Device (Rev. A)PDF, 72 Кб, Версия: A, Файл опубликован: 22 мар 2010
The MSP430 series of microprocessors are fast powerful devices ideally suited for use with the various wireless transceivers offered by Texas Instruments. In streaming audio applications, however, it is desirable that the microprocessor support an audio bus to allow for interconnection to an audio CODEC. This application note describes how to create an I2S-like bus (left-justified mode) from an SP - Audio Serial Interface Configurations for Audio CodecsPDF, 70 Кб, Файл опубликован: 22 сен 2010
An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
Серия: TLV320DAC3101 (2)
- TLV320DAC3101IRHBR TLV320DAC3101IRHBT
- Semiconductors > Audio > Audio Converters > Audio DAC
