Datasheet Texas Instruments TLV320DAC3101IRHBT — Даташит
СерияTLV320DAC3101
МодельTLV320DAC3101IRHBT
Маломощный стереоаудио ЦАП с усилителем стереодинамиков класса D 32-VQFN от -40 до 85
Low-Power Stereo Audio DAC With Stereo Class-D Speaker Amplifier datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 1 май 2012
Pin32
Package TypeRHB
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаDAC3101
Width (мм)5
Length (мм)5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Analog Inputs2
Analog Outputs4
АрхитектураClass D
Control InterfaceI2C
DAC Channels2
DAC SNR(Typ)95 дБ
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
Разрешение32 Bits
Sampling Rate(Max)192 kHz
  • Evaluation Modules & Boards: TLV320DAC3101EVM-U
    TLV320DAC3101EVM-U Evaluation Module
  • TLV320AIC31xx and TLV320DAC31xx Power Consumption Characterization (Rev. B)
    PDF, 136 Кб, Версия: B, Файл опубликован: 3 сен 2014
  • Coefficient RAM Access Mechanisms.. (Rev. D)
    PDF, 140 Кб, Версия: D, Файл опубликован: 25 янв 2012
  • Interfacing an I2S Device to an MSP430 Device (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 22 мар 2010
    The MSP430 series of microprocessors are fast powerful devices ideally suited for use with the various wireless transceivers offered by Texas Instruments. In streaming audio applications, however, it is desirable that the microprocessor support an audio bus to allow for interconnection to an audio CODEC. This application note describes how to create an I2S-like bus (left-justified mode) from an SP
  • Audio Serial Interface Configurations for Audio Codecs
    PDF, 70 Кб, Файл опубликован: 22 сен 2010
    An audio serial interface (ASI) provides a means to transfer non-buffered audio data between processors and/or audio converters. These data are typically encoded in PCM twos complement format, although other format variations may be possible to achieve companding for lower data rate transfers. Audio converters based on the delta-sigma (О”ОЈ) architecture require an internal master clock
Серия: TLV320DAC3101 (2)
  • Semiconductors > Audio > Audio Converters > Audio DAC
На английском языке: Datasheet Texas Instruments TLV320DAC3101IRHBT
