Datasheet Texas Instruments TLV8544PWR — Даташит
СерияTLV8544
МодельTLV8544PWR
500 нА Quad, RRIO, наномощный операционный усилитель для экономичных систем 14-TSSOP от -40 до 125
TLV8544, TLV8542 500 nA RRIO Nanopower Operational Amplifier datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 20 июн 2017
Pin14
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаTL8544
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesCost Optimized,EMI Hardened
АрхитектураCMOS
CMRR(Min)60 дБ
CMRR(Typ)75 дБ
GBW(Typ)0.008 МГц
Iq per channel(Max)0.00064 мА
Iq per channel(Typ)0.0005 мА
Количество каналов4
Offset Drift(Typ)0.8 uV/C
Output Current(Typ)15 мА
Package GroupTSSOP
Package Size: mm2:W x L14TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Rail-to-RailIn,Out
Slew Rate(Typ)0.0035 V/us
Total Supply Voltage(Max)3.6 +5V=5, +/-5V=10
Total Supply Voltage(Min)1.7 +5V=5, +/-5V=10
Vn at 1kHz(Typ)264 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)3.1 мВ
  • Evaluation Modules & Boards: DIYAMP-EVM
    Universal Do-It-Yourself (DIY) Amplifier Circuit Evaluation Module
  • Evaluation Modules & Boards: BOOSTXL-TLV8544PIR
    TLV8544 Quad Nanopower Op amp PIR Motion Detector Demonstration Module
  • Cost-Optimized Opamp Window Comparator for Ultra-low Power PIR Motion Detectors
    PDF, 115 Кб, Файл опубликован: 6 мар 2017
    A window comparator is a combination of anoninverting and an inverting comparators along withtwo reference voltages. When the signal at the input of the windowcomparator crosses either thresholds, thecorresponding output changes state to an oppositevoltage level at the output.
  • Design of Ultra-Low Power Circuits for Battery-Powered Wireless PIR Motion Detec (Rev. A)
    PDF, 479 Кб, Версия: A, Файл опубликован: 12 май 2017
    In this document, a cost-optimized, ultra-low power op amp interface for wireless battery operated PIR (Passive Infrared) motion detectors is described. A single new 4-channel nanopower operational amplifier, TLV8544, implements the analog signal path, including two gain stages, two bandpass filters, and a window comparator.
Серия: TLV8544 (1)
  • TLV8544PWR
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Ultra-Low-Power Op Amps (<=10uA)
На английском языке: Datasheet Texas Instruments TLV8544PWR
