Datasheet Texas Instruments TM4C1236E6PM — Даташит
СерияTM4C1236E6PM
High performance 32-bit ARMВ® CortexВ®-M4F based MCU
Tivaв„ў C Series TM4C1236E6PM Microcontroller Data Sheet datasheet
PDF, 7.5 Мб, Версия: E, Файл опубликован: 20 июн 2014
TM4C1236E6PMI7TM4C1236E6PMI7R
N12
Pin6464
Package TypePMPM
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY1601000
CarrierJEDEC TRAY (10+1)
МаркировкаE6PMI7E6PMI7
Width (мм)1010
Length (мм)1010
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
Parameters / ModelsTM4C1236E6PMI7
TM4C1236E6PMI7
TM4C1236E6PMI7R
TM4C1236E6PMI7R
10/100 ENET MACNoNo
10/100 ENET MAC+PHYNoNo
ADC Channels1212
ADC Resolution, Bits1212
Bi- and Quad- SSI/SPINoNo
CAN MAC11
CPUARM Cortex-M4FARM Cortex-M4F
EEPROM, KB22
External Peripheral InterfaceNoNo
Flash, KB128128
Тактовая частота, МГц8080
GPIO4949
I2C66
I2SNoNo
LCDNoNo
LCD ControllerNoNo
Max Speed, МГц8080
Non-volatile Memory, KB22
Рабочий диапазон температур, Cот -40 до 85от -40 до 85
Package GroupLQFPLQFP
Package Size: mm2:W x L, PKG64LQFP: 144 mm2: 12 x 12(LQFP)64LQFP: 144 mm2: 12 x 12(LQFP)
Pin & Package64LQFP64LQFP
Pin/Package64LQFP64LQFP
RAM, KB2424
RTCYesYes
RatingCatalogCatalog
SPI44
SRAM, kB3232
SSI/SPI44
SecurityNo HW acceleratorNo HW accelerator
SysTickYesYes
UART88
USB D, H/D, or OTGOTGOTG
USB High-Speed with ULPINoNo
Watchdog Timers22
RoHSСовместимСовместим
  • Implementation of Programmer for Serial Bootloaders on TM4C12x Microcontroller (Rev. A)
    PDF, 2.5 Мб, Версия: A, Файл опубликован: 21 апр 2016
    TM4C12x microcontrollers from Texas Instruments feature ROM and Flash-based bootloaders. The bootloaders are used to download an application image to the microcontroller over universal asynchronous receiver/transmitter (UART), inter-integrated circuit (I2C), synchronous serial interface (SSI), universal serial bus (USB) or Ethernet (TM4C129x device family only) without the need to connect a JTAG o
  • Using TM4C12x Devices Over JTAG Interface
    PDF, 1.9 Мб, Файл опубликован: 18 авг 2016
    The IEEE Standard 1149.1-1990, IEEE Standard Test Access Port and Boundary-Scan Architecture (JTAG) is a method for verifying designs and testing printed circuit boards after assembly. It is used as the primary means for transferring data to a nonvolatile memory of an embedded system and debugging embedded software.This application report describes the physical connections for JTAG and desi
  • StellarisВ® Graphics Library Display Drivers (AN01287) (Rev. A)
    PDF, 67 Кб, Версия: A, Файл опубликован: 9 июл 2013
    The Stellaris Graphics Library (grlib) offers a compact yet powerful collection of graphics functions allowing the development of compelling user interfaces on small monochrome or color displays attached to Stellaris microcontrollers. This application report describes how to support a new display device in the Stellaris Graphics Library.
  • Transitioning Designs From Stellaris LM3S Microcontrollers to Tiva C Series MCUs (Rev. A)
    PDF, 104 Кб, Версия: A, Файл опубликован: 22 окт 2013
    This application report addresses design considerations when migrating working designs from Stellaris LM3S microcontrollers to Tiva C Series microcontrollers. Topics covered include software and hardware considerations as well as feature changes and enhancements. Software migration is very straightforward when using the Driver Library APIs in the StellarisWareВ® and TivaWareв„ў for C Series
  • System Design Guidelines for the TM4C123x Family of Tiva C Series MCUs
    PDF, 1.5 Мб, Файл опубликован: 31 июл 2013
  • Migrating Software Projects from StellarisWare to TivaWare for C Series Software (Rev. A)
    PDF, 92 Кб, Версия: A, Файл опубликован: 1 май 2013
    As TI launches the Tivaв„ў family of 32-bit ARMВ® Cortexв„ў-M4 microcontrollers (MCUs), the StellarisWareВ® suite of comprehensive software tools is also migrating to TivaWareв„ў. This new software platform offers the same features found in earlier versions, but a few changes have been made in the migration process that require simple modifications to be made in existing StellarisWare applications in orde
  • Using the CMSIS DSP Library in Code Composer Studio for TM4C MCUs (Rev. G)
    PDF, 3.0 Мб, Версия: G, Файл опубликован: 7 окт 2015
    This application report describes the process required to build the ARMВ® CMSIS DSP library in Code Composer Studio v6.1 with ARM Compiler version up to 5.2.5. This document also describes how to use Code Composer Studio v6.1 to build, run, and verify the 11 ARM DSP example projects that are included in the CMSIS package.
  • Powering Cortex-M4 MCUs Using the High Efficiency DCS-Control Topology
    PDF, 164 Кб, Файл опубликован: 3 фев 2013
    The new Tiva C Series ARMВ® Cortexв„ў-M4 family of versatile microcontrollers provides prolific connectivity peripherals, such as the industry's first integrated Ethernet MAC and PHY, advanced analog integration and hardware floating-point performance. This application report presents an ultra-low IQ (4.8 ОјA) power supply solution for Tiva C Series devices using the TPS62177, a high efficiency synchr
  • Dual-SPI Emulating IВІS on Tivaв„ў C Series TM4C123x MCUs (Rev. B)
    PDF, 436 Кб, Версия: B, Файл опубликован: 12 июн 2013
    This application report presents an example using two serial peripheral interfaces (SPIs) to emulate an integrated interchip sound (I2S) peripheral on the StellarisВ® LM4F232 (Tiva C series TM4C123GH6PGE) microcontroller. Utilizing the sound API, .wav audio files stored in the on-board SD card are played via pseudo-I2S to an external Texas Instruments' TLV320AIC3107 codec. This generic software pla
  • Using AES Encryption and Decryption with Stellaris Microcontrollers (AN01251) (Rev. B)
    PDF, 113 Кб, Версия: B, Файл опубликован: 8 янв 2010
    This application note describes the following four encryption methods used with AES: Electronic code book (ECB), cipher block chaining (CBC) or chained encryption, cipher feedback (CFB), and counter (CTR). These methods are described in more detail to help you select the appropriate method(s) for your application. The encryption package described in this application note is available with full sou
Серия: TM4C1236E6PM (2)
  • Semiconductors> Microcontrollers (MCU)> Performance MCUs> Control + Automation> TM4C12x
На английском языке: Datasheet Texas Instruments TM4C1236E6PM
