Datasheet SSM2166SZ - Analog Devices Даташит PRE-AMP, MICROPHONE, 2166, NSOIC14 — Даташит
Наименование модели: SSM2166SZ
![]() 45 предложений от 27 поставщиков Микросхема Усилитель звуковой частоты, Audio Power Amplifier, 1Channel, 4.5V to 5.5V, SOIC, 14Pins | |||
SSM2166SZ Analog Devices | 83 ₽ | ||
SSM2166SZ Analog Devices | от 959 ₽ | ||
Мультимедиа преобразователь SSM2166SZ Analog Devices | 1 153 ₽ | ||
SSM2166SZ Analog Devices | по запросу |
Производитель: Analog Devices
Описание: PRE-AMP, MICROPHONE, 2166, NSOIC14
Microphone Preamplifier with Variable Compression and Noise Gating SSM2166*
FEATURES Complete Microphone Conditioner in a 14-Lead Package Single +5 V Operation Adjustable Noise Gate Threshold Compression Ratio Set by External Resistor Automatic Limiting Feature--Prevents ADC Overload Adjustable Release Time Low Noise and Distortion Power-Down Feature 20 kHz Bandwidth ( 1 dB) Low Cost APPLICATIONS Microphone Preamplifier/Processors Computer Sound Cards Public Address/Paging Systems Communication Headsets Telephone Conferencing Guitar Sustain Effects Generators Computerized Voice Recognition Surveillance Systems Karaoke and DJ Mixers GENERAL DESCRIPTION
this gain is in addition to the variable gain in other compression settings.
The input buffer can also be configured for front-end gains of 0 dB to 20 dB. A downward expander (noise gate) prevents amplification of noise or hum. This results in optimized signal levels prior to digitization, thereby eliminating the need for additional gain
- Количество каналов: 1
- Диапазон напряжения питания: 4.5 В ... 5.5 В
- THD + N: 0.25% @ 100 кОм, V=5V
- Load Impedance: 75 Ом
- Amplifier Case Style: SOIC
- Количество выводов: 14
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: NSOIC
- Amplifier Type: Microphone Preamplifier
- Bandwidth: 20 МГц
- Семейство: 2166
- IC Generic Number: 2166
- Load Impedance Min: 100000 Ом
- Количество логических функций: 2166
- Number of Amplifiers: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- Supply Voltage + Nom: 10 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Electrolube - HTS35SL
