Datasheet ТI TMP468 — Даташит
СерияTMP468
Datasheet Texas Instruments TMP468
В±0.75вЃ°C High-Accuracy Multi-channel Remote and Local Temperature Sensor
TMP468 9-Channel (8-Remote and 1-Local), High-Accuracy Temperature Sensor datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 16 июн 2017
TMP468AIRGTRTMP468AIRGTTTMP468AIYFFRTMP468AIYFFT
Статус продуктаВ производствеВ производствеВ производствеВ производстве
Доступность образцов у производителяНетНетДаДа
N1234
Pin16161616
Package TypeRGTRGTYFFYFF
Industry STD TermVQFNVQFNDSBGADSBGA
JEDEC CodeS-PQFP-NS-PQFP-NS-XBGA-NS-XBGA-N
Package QTY30002503000250
CarrierLARGE T&RSMALL T&RLARGE T&RSMALL T&R
МаркировкаT468T468TMP468TMP468
Width (мм)33
Length (мм)33
Thickness (мм).9.9.425.425
Pitch (мм).5.5.4.4
Max Height (мм)11.625.625
Parameters / ModelsTMP468AIRGTR
TMP468AIRGTR
TMP468AIRGTT
TMP468AIRGTT
TMP468AIYFFR
TMP468AIYFFR
TMP468AIYFFT
TMP468AIYFFT
InterfaceI2C,SMBusI2C,SMBusI2C,SMBusI2C,SMBus
Local Sensor Accuracy(Max), +/- C0.350.350.350.35
Рабочий диапазон температур, Cот -40 до 125от -40 до 125от -40 до 125от -40 до 125
Package GroupVQFNVQFNDSBGADSBGA
Package Size: mm2:W x L, PKG16VQFN: 9 mm2: 3 x 3(VQFN)16VQFN: 9 mm2: 3 x 3(VQFN)See datasheet (DSBGA)See datasheet (DSBGA)
RatingCatalogCatalogCatalogCatalog
Remote Channel8888
Remote Diode Temp Range for Listed Accuracy, C-55 to 150-55 to 150-55 to 150-55 to 150
Remote Sensor Accuracy(Max), +/- C0.750.750.750.75
Remote Sensor CorrectionOffset Correction Register,Series Resistance Cancellation,n-Factor CorrectionOffset Correction Register,Series Resistance Cancellation,n-Factor CorrectionOffset Correction Register,Series Resistance Cancellation,n-Factor CorrectionOffset Correction Register,Series Resistance Cancellation,n-Factor Correction
Remote Temp Resolution(Max), bits13131313
Special FeaturesOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detectionOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detectionOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detectionOne shot conversion control,Programmable Alert,Programmable conversion rate,Remote diode fault detection
Supply Current(Typ), uA67676767
Supply Voltage(Max), В3.63.63.63.6
Supply Voltage(Min), В1.71.71.71.7
RoHSСовместимСовместимСовместимСовместим
  • Optimizing Remote Diode Temperature Sensor Design
    PDF, 1.2 Мб, Файл опубликован: 19 янв 2017
  • Semiconductors> Sensing Products> Temperature Sensors> Remote / Multi-channel Temperature Sensors
На английском языке: Datasheet Texas Instruments TMP468
Политика конфиденциальности
