Datasheet Texas Instruments TMS320C240 — Даташит
СерияTMS320C240
16-битный DSP с фиксированной точкой, 5 В
TMS320C240PQ
Статус продуктаНе рекомендуется для новых разработок
TMS320C240PQ
N1
Pin132
Package TypePQ
Industry STD TermBQFP
JEDEC CodeS-PQFP-G
Width (мм)24.13
Length (мм)27.44
Thickness (мм)3.56
Pitch (мм).635
Max Height (мм)4.57
TMS320C240PQ
RoHSНе совместим
  • AC Induct'n Motor Control Using Constant V/Hz Principle/Space Vector PWM- 'C240 (Rev. A)
    PDF, 500 Кб, Версия: A, Файл опубликован: 1 янв 1998
    The principles of constant V/Hz control for AC Induction motor and space vector PWM technique are reviewed. Two different implementations are presented. Implementation issues such as command voltage generation, switching pattern determination, speed measurement and scaling are discussed. Experimental data are shown. Full programs are attached in the appendices.
  • Monitoring TMS320C240 Peripheral Registers in the Debugger Software
    PDF, 44 Кб, Файл опубликован: 1 июн 1997
    This document discusses how to view the peripheral registers on a 'C240 or 'F240 device while running the emulator. It includes a lengthy code example.
  • Obtaining Absolute Encoder Position on a TMS320C240
    PDF, 78 Кб, Файл опубликован: 1 июн 1997
    Many servo applications require absolute position information as feedback. This document describes how the encoder count can be processed to obtain absolute position on the TMS320C240. The document includes a theoretical discussion, equations, timing diagrams and a lengthy code example.
  • TMS320C/F240 Evaluation Board Initialization Software
    PDF, 50 Кб, Файл опубликован: 1 июн 1997
    The TMS320C/F240 Evaluation Module provides a tool that makes it easier to design the software elements of a system when taking the initial steps in the development of a new application.This note allows the user, once the necessary tools have been installed, to quickly start developing code based on the TMS320C/F240 Evaluation Module. This document describes how to use the tools and provides a
  • DSP Solution for Permanent Magnet Synchronous Motor
    PDF, 210 Кб, Файл опубликован: 1 янв 1996
    This document presents a solution to control a permanent magnet synchronous motor using the TMS320C24x. This new family of DSPs enables cost-effective design of intelligent controllers for brushless motors which can fulfill enhanced operations, consisting of fewer system components, lower system cost and increased performances. The control method presented relies on the field orientated control (F
  • DSP Solution for AC Induction Motor
    PDF, 183 Кб, Файл опубликован: 1 янв 1996
    The Motor Control industry is a strong aggressive sector. Each industry to remain competitive, must reduce costs but also has to answer to power consumption reduction and EMI radiation reduction issues imposed by governments and power plant lobbies. The results of these constraining factors are the need of enhanced algorithms. DSP technology allows to achieve both, a high level of performance as
  • Implementation of a Speed Controlled Brushless DC Drive Using TMS320F240
    PDF, 157 Кб, Файл опубликован: 1 янв 1997
    The DSP Controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives. TMS320F240 provides a single chip solution by integrating on-chip not only a high computational power but, also, all the peripherals necessary for electric motor control. The main benefits are increased system reliability and cost reduction of the overall system. The present application note describ
Серия: TMS320C240 (1)
  • Semiconductors> Microcontrollers (MCU)> Performance MCUs> Real-time Control> C24x 16-bit Series
На английском языке: Datasheet Texas Instruments TMS320C240
