Datasheet Texas Instruments TMS320C26B — Даташит
СерияTMS320C26B
Цифровые сигнальные процессоры
Datasheet
TSP
TMS320C26BFN
Статус продуктаСнят с производства
TMS320C26BFN
N1
Pin68
Package TypeFN
Industry STD TermPLCC
JEDEC CodeS-PQCC-J
Width (мм)24.23
Length (мм)24.23
Thickness (мм)4.06
Max Height (мм)4.57
TMS320C26BFN
RoHSНе совместим
  • Implementing Split Spectrum Processing With a TMS320C26 DSP
    PDF, 2.3 Мб, Файл опубликован: 1 июн 1997
    The ultrasonic evaluation of specimens with large microstructures can be difficult because of interference caused by the grains in the material. The split spectrum processing (SSP) filtering technique effectively reduces this type of noise by employing a bank of filters followed by a nonlinear detector that increases signal-to-noise ratios. This application report describes the benefits of imp
  • Engine Knock Detection Using Spectral Analysis With TMS320C25 or TMS320C30 DSPs
    PDF, 254 Кб, Файл опубликован: 1 янв 1995
    An efficient method of detecting combustion engine knock is using spectral analysis. The detection process algorithm adapts to a no-knock reference at varying speeds and loads by using multiple frequencies. This document presents an problem overview current technology and two implementation examples are given to aid in the development of system specific hardware and software. The first system is
  • Minimizing Quantization Effects Using the TMS320 DSP Family
    PDF, 268 Кб, Файл опубликован: 1 июл 1994
    Due to its discrete nature DSPs represent variables and performs arithmetic functions with a finite word length. This produces three effects: the selection of filter transfer functions is quantized with filter poles and zeros existing only at specific locations in the z plane; the input is quantized; and noise is introduced from DSP multiplication and division operations. This document shows how
  • Setting Up TMS320 DSP Interrupts in 'C'
    PDF, 168 Кб, Файл опубликован: 1 ноя 1994
    Four steps are required to set the TMS320 DSP interrupts: create a interrupt service routine initialize the vector table and set the memory map enable the interrupts in the CPU and enable the interrupt sources. This document shows how to set the interrupts in C C callable assembly or in-line C. Sample C code segments are provided. The appendix gives complete examples for setting interrupt vec
Серия: TMS320C26B (1)
  • Semiconductors> Processors> Other Processors
На английском языке: Datasheet Texas Instruments TMS320C26B
