Datasheet Texas Instruments TMS320C54X — Даташит
СерияTMS320C54X
Цифровой сигнальный процессор
Datasheet
TSP
TMS320C54X32GHH035
Статус продуктаСнят с производства
TMS320C54X32GHH035
N1
Pin180
Package TypeGHH
TMS320C54X32GHH035
RoHSНе совместим
  • Interfacing the TMS320C54x DSP to the TLC320AD535 /545 Codecs
    PDF, 106 Кб, Файл опубликован: 18 фев 2000
    This application report presents a method for interfacing the TLC320AD535 and TLC320AD545 codecs from Texas Instruments (TI)(tm) with the multichannel buffered serial port (McBSP) on TI's C54xx family of digital signal processors (DSPs). As is the case with many codecs from TI, these devices utilize a primary and secondary communication protocol to differentiate between actual signal data and code
  • TMS320C54x DSP Reference Framework & Device Driver for the TLV320AIC20 HPA DC
    PDF, 692 Кб, Файл опубликован: 16 янв 2003
    The TLV320AIC20 is a high performance analog (HPA) data converter geared for voiceband digital applications (typically 8-kHz sampling rates.) The TLV320AIC20EVM is an evaluation module that connects to a TI DSP starter kit (DSK) via a standard AIC motherboard (Part no. AICDEVPLATEVM). The EVM contains two AIC20 dual-codec devices connected in a cascaded configuration, allowing the user to config
Серия: TMS320C54X (1)
  • Semiconductors> Processors> Digital Signal Processors> C5000 DSP> Other C5000 DSP
На английском языке: Datasheet Texas Instruments TMS320C54X
