Datasheet Texas Instruments TMS320C6726 — Даташит
СерияTMS320C6726
Процессор цифровых сигналов с плавающей запятой
Datasheet
TSP
TMS320C6726RFP225TMX320C6726RFP
Статус продуктаСнят с производстваСнят с производства
N12
Pin144144
Package TypeRFPRFP
Industry STD TermHTQFPHTQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Width (мм)2020
Length (мм)2020
Thickness (мм)11
Pitch (мм).5.5
Max Height (мм)1.21.2
RoHSНе совместимНе совместим
Бессвинцовая технология (Pb Free)НетНет
  • How to Create Delay-based Audio Effects on a TMS320C6727 DSP
    PDF, 600 Кб, Файл опубликован: 1 ноя 2005
    TMS320C672x is a floating point device family from Texas Instruments that provides high quality audio performance at low prices. The price/performance ratio makes C672x well suited for numerous audio applications. This application note shows how to use C672x to efficiently create delay-based audio effects. The application note explains:How to leverage the data movement accelerator (dM
  • Using the TMS320C672x Bootloader (Rev. D)
    PDF, 456 Кб, Версия: D, Файл опубликован: 10 сен 2009
    This application report describes the design details of the TMS320C672x bootloader and describes a set of software utilities designed to facilitate formatting of application code for use with the bootloader.This application report contains a system level patch, the bootloader utilities and project code that can bedownloaded from this link:
  • TMS320C672x Power Consumption Summary (Rev. B)
    PDF, 55 Кб, Версия: B, Файл опубликован: 22 сен 2006
    This document discusses the power consumption of the Texas Instruments TMS320C672x digital signal processor (DSP). Power consumption on TMS320C67x™ devices is highly application-dependent. A spreadsheet is provided to model power consumption for the user’s application. To get good results from the spreadsheet, realistic usage parameters must be entered. The low-core voltage and other power d
  • TMS320C672x Hardware Designer's Resource Guide (Rev. A)
    PDF, 87 Кб, Версия: A, Файл опубликован: 22 сен 2006
    The DSP Hardware Designer's Resource Guide is organized by development flow and functional areas to make your design effort as seamless as possible. Topics covered include getting started, board design, system testing, and checklists to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, models, symbols, and refere
  • C9230C100 TMS320C672x Floating-Point Digital Signal Processor ROM (Rev. C)
    PDF, 60 Кб, Версия: C, Файл опубликован: 25 сен 2006
    Describes the features of the C9230C100 TMS320C672x digital signal processor ROM. The system level patch, bootloader utilities and example code, can be downloaded from this link: http://www-s.ti.com/sc/psheets/sprc203/sprc203.zip.
  • TMS320C6713 to TMS320C672x Migration Guide
    PDF, 182 Кб, Файл опубликован: 23 май 2005
  • Thermal Considerations for the DM64xx, DM64x, and C6000 Devices
    PDF, 127 Кб, Файл опубликован: 20 май 2007
    As integrated circuit (IC) components become more complex, the challenge of producing an end product with superior thermal performance increases. Thermal performance is a system level concern, impacted by IC packaging as well as by printed circuit board (PCB) design. This application report addresses the thermal considerations for the TMS320DM64xx, TMS320DM64x, and TMS320C6000в„ў DSP devices.
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
Серия: TMS320C6726 (2)
  • Semiconductors> Processors> Digital Signal Processors> C6000 DSP> Other C6000 DSP
На английском языке: Datasheet Texas Instruments TMS320C6726
