Datasheet Texas Instruments TMS320LF2407 — Даташит
СерияTMS320LF2407
16-битный DSP с фиксированной запятой и Flash
TMS320LF2407, TMS320LF2406, TMS320LF2402 DSP Controllers (Rev. I)
PDF, 1.5 Мб, Версия: I, Файл опубликован: 11 сен 2003
TMS320LF2407PGEATMS320LF2407PGESTMX320LF2407APGE
Статус продуктаСнят с производстваСнят с производстваСнят с производства
Доступность образцов у производителяНетНетНет
N123
Pin144144144
Package TypePGEPGEPGE
Industry STD TermLQFPLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-GS-PQFP-G
Width (мм)202020
Length (мм)202020
Thickness (мм)1.41.41.4
Pitch (мм).5.5.5
Max Height (мм)1.61.61.6
RoHSНе совместимНе совместимНе совместим
Бессвинцовая технология (Pb Free)НетНетНет
  • DSP Solution for AC Induction Motor
    PDF, 183 Кб, Файл опубликован: 1 янв 1996
    The Motor Control industry is a strong aggressive sector. Each industry to remain competitive, must reduce costs but also has to answer to power consumption reduction and EMI radiation reduction issues imposed by governments and power plant lobbies. The results of these constraining factors are the need of enhanced algorithms. DSP technology allows to achieve both, a high level of performance as
  • Implementation of a Speed Controlled Brushless DC Drive Using TMS320F240
    PDF, 157 Кб, Файл опубликован: 1 янв 1997
    The DSP Controller TMS320F240 from Texas Instruments is suitable for a wide range of motor drives. TMS320F240 provides a single chip solution by integrating on-chip not only a high computational power but, also, all the peripherals necessary for electric motor control. The main benefits are increased system reliability and cost reduction of the overall system. The present application note describ
  • Semiconductors> Microcontrollers (MCU)> Performance MCUs> Real-time Control> C24x 16-bit Series
На английском языке: Datasheet Texas Instruments TMS320LF2407
