Datasheet Texas Instruments TMS3705BDRG4 — Даташит
СерияTMS3705
МодельTMS3705BDRG4
НЧ-считыватель IC 16-SOIC от -40 до 85
TMS3705 Transponder Base Station IC datasheet
PDF, 958 Кб, Версия: D, Файл опубликован: 21 окт 2016
Pin16
Package TypeD
Package QTY2500
МаркировкаTMS3705B
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Device TypeReader
Размеры10 x 6 мм
Тактовая частота134.2 kHz
КорпусSO16 мм
StandardISO 11785
TechnologySecure ICs and Transponders for Automotive
Throughput(Max)N/A Mbps
Transmission PrincipleHDX - FSK
  • Evaluation Modules & Boards: RI-ACC-ADR2-10
    Low Frequency Demo Reader
  • Evaluation Modules & Boards: EZ430-TMS37157
    PaLFI, Passive Low Frequency Evaluation Kit TMS37157
  • TMS3705 Passive Antenna Solution
    PDF, 454 Кб, Файл опубликован: 12 июл 2010
    The Texas Instruments low-frequency transponder technology provides the possibility to use a simple passive antenna in combination with various antenna cable lengths. This solution significantly reduces system costs because the active part of the transceiver can be added to the already existing host system, e.g., the body control module (BCM) of a vehicle.In comparison to a standard system, n
  • Integrated TIRIS RF Module TMS3705A Introduction to Low Frequency Reader
    PDF, 177 Кб, Файл опубликован: 1 окт 1999
  • TMS3705 Range Extender Power Solution Using UCC27424-Q1
    PDF, 396 Кб, Файл опубликован: 9 авг 2012
    This application report provides supplementary information about the Texas Instruments 134.2 kHz RFID Base Station IC TMS3705x in combination with an external driver IC. In particular, the document shows a low cost and easy-to-implement solution to improve the communication distance between the transaction processor (TRP) and the Reader unit.
  • Resonant Trimming Sequence
    PDF, 88 Кб, Файл опубликован: 9 янв 2013
    This application report presents an efficient and precise method on how to achieve the desired resonant frequency of configuring the trim array with only a few iterations and measuring the resonant frequency. First, the minimum and maximum resonant frequency is measured; from this data a capacitance gradient is derived, which allows a good prediction of the required capacitance. The calculated cap
Серия: TMS3705 (4)
  • Semiconductors > Wireless Connectivity > NFC / RFID
На английском языке: Datasheet Texas Instruments TMS3705BDRG4
