Datasheet Texas Instruments TMS37145TEAIE — Даташит
СерияTMS37145
МодельTMS37145TEAIE
TMS37145 Digital Signal Transponder With DST80 Auth, EEPROM, LF Immobilizer datasheet
PDF, 90 Кб, Файл опубликован: 24 май 2012
Package TypeTEA
Package QTY2000
CarrierBULK
Device TypeTransponder
Размеры12 x 6 x 3 мм
Тактовая частота134.2 kHz
КорпусPlastic Wedge мм
StandardTI protocol
TechnologySecure ICs and Transponders for Automotive
Throughput(Max)N/A Mbps
Transmission PrincipleHDX - FSK
  • TMS3705 Range Extender Power Solution Using UCC27424-Q1
    PDF, 396 Кб, Файл опубликован: 9 авг 2012
    This application report provides supplementary information about the Texas Instruments 134.2 kHz RFID Base Station IC TMS3705x in combination with an external driver IC. In particular, the document shows a low cost and easy-to-implement solution to improve the communication distance between the transaction processor (TRP) and the Reader unit.
  • Resonant Trimming Sequence
    PDF, 88 Кб, Файл опубликован: 9 янв 2013
    This application report presents an efficient and precise method on how to achieve the desired resonant frequency of configuring the trim array with only a few iterations and measuring the resonant frequency. First, the minimum and maximum resonant frequency is measured; from this data a capacitance gradient is derived, which allows a good prediction of the required capacitance. The calculated cap
Серия: TMS37145 (1)
  • TMS37145TEAIE
  • Semiconductors > Wireless Connectivity > NFC / RFID
На английском языке: Datasheet Texas Instruments TMS37145TEAIE
