Datasheet Texas Instruments TMS37145 — Даташит
СерияTMS37145
Транспондер цифрового сигнала с аутентификацией DST80, EEPROM и LF-иммобилайзером
TMS37145 Digital Signal Transponder With DST80 Auth, EEPROM, LF Immobilizer datasheet
PDF, 90 Кб, Файл опубликован: 24 май 2012
TMS37145TEAIE
Статус продуктаВ производстве
TMS37145TEAIE
N1
Package TypeTEA
Package QTY2000
CarrierBULK
Parameters / ModelsTMS37145TEAIE
TMS37145TEAIE
Device TypeTransponder
Размеры, мм12 x 6 x 3
Тактовая частота134.2 kHz
Рабочий диапазон температур, Cот -40 до 85
Корпус, ммPlastic Wedge
StandardTI protocol
TechnologySecure ICs and Transponders for Automotive
Throughput(Max), MbpsN/A
Transmission PrincipleHDX - FSK
TMS37145TEAIE
  • Resonant Trimming Sequence
    PDF, 88 Кб, Файл опубликован: 9 янв 2013
    This application report presents an efficient and precise method on how to achieve the desired resonant frequency of configuring the trim array with only a few iterations and measuring the resonant frequency. First, the minimum and maximum resonant frequency is measured; from this data a capacitance gradient is derived, which allows a good prediction of the required capacitance. The calculated cap
  • TMS3705 Range Extender Power Solution Using UCC27424-Q1
    PDF, 396 Кб, Файл опубликован: 9 авг 2012
    This application report provides supplementary information about the Texas Instruments 134.2 kHz RFID Base Station IC TMS3705x in combination with an external driver IC. In particular, the document shows a low cost and easy-to-implement solution to improve the communication distance between the transaction processor (TRP) and the Reader unit.
Серия: TMS37145 (1)
  • Semiconductors> Wireless Connectivity> NFC / RFID
На английском языке: Datasheet Texas Instruments TMS37145
