Datasheet Texas Instruments TMS37157IRSARG4 — Даташит
СерияTMS37157
МодельTMS37157IRSARG4
Устройство пассивного низкочастотного интерфейса (PaLFI) с EEPROM и интерфейсом транспондера 134,2 кГц 16-QFN от -40 до 85
Passive Low Frequency Interface Device With EEPROM and 134.2 kHz Transponder datasheet
PDF, 1.7 Мб, Версия: A, Файл опубликован: 5 ноя 2009
Pin1616
Package TypeRSARSA
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
МаркировкаI37157
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).65.65
Max Height (мм)11
Device TypeTransponder
Размеры4 x 4 мм
Тактовая частота134.2 kHz
КорпусQFN16 мм
StandardTI protocol
TechnologyN/A
Throughput(Max)N/A Mbps
Transmission PrincipleHDX - FSK
  • Evaluation Modules & Boards: EZ430-TMS37157
    PaLFI, Passive Low Frequency Evaluation Kit TMS37157
  • Communicating With the RFID Base Station
    PDF, 199 Кб, Файл опубликован: 21 сен 2011
    This document describes the USB RFID base station that is delivered with the eZ430-TMS37157 demo tool. It does not describe the GUI that is delivered with the tool [for a description of the GUI and other information about the tool, see the eZ430-TMS37157 Development Tool User's Guide (SLAU281)]. This application report helps the reader design a custom Windows GUI to control the RFID base station.
  • TMS37157 Passive Low-Frequency Interface IC Performance With Neosid Antennas (Rev. A)
    PDF, 2.4 Мб, Версия: A, Файл опубликован: 19 апр 2013
    The Texas Instruments low-frequency transponder technology provides the possibility to use the TMS37157 (PaLFI) IC in combination with various antennas to meet application performance requirements.For cost optimization purposes, off the shelf antennas can be used from various coil manufacturers.This application report describes the performance measured with the antennas available fro
  • Low-Frequency RFID in a Nutshell
    PDF, 2.0 Мб, Файл опубликован: 21 сен 2011
    This application report describes the principles of Texas Instruments low-frequency RFID products, how to choose the right components, and shows best practices for a good PCB layout. This application report can be used as a guideline for designing a system with the TMS37157 PaLFI chip.
  • LF HDX System Parameter Calculation for TMS37157 (PaLFI)
    PDF, 1.0 Мб, Файл опубликован: 15 июл 2010
    The Texas Instruments low frequency half-duplex (HDX) transponder technology allows the possibility to improve the communication distance between the transponder and reader. This application report provides information for the calculation of the basic system parameters.The TMS37157 TI transponder IC is based on the TI HDX RFID concept. Using the given formulas, the performance and component
  • Using the SPI Library for TMS37157
    PDF, 68 Кб, Файл опубликован: 19 дек 2011
    This document describes the SPI Commands that are necessary to control the TMS37157 passive low-frequency interface (PaLFI) device and access its EEPROM. The functions of the SPI library are in C and can be easily called from any C program that includes the header files. The header files are optimized for the MSP430F2274 and can be easily adapted to other microcontrollers. The SPI library does not
  • Low-Power Battery-Less Wireless Temperature and Humidity Sensor for TMS37157
    PDF, 1.8 Мб, Файл опубликован: 19 дек 2011
    This application report describes a battery-less operation of a temperature and humidity sensor application. The implementation is done using the SHT21 relative humidity and temperature (RH&T) sensor from Sensirion (http://www.sensirion.com), an MSP430F2274 microcontroller, and the TMS37157 (PaLFI) low-frequency device from TI. The complete power for operating the wireless sensor and the MSP430F22
  • Passive RFID Application Using MSP430F2274
    PDF, 2.5 Мб, Файл опубликован: 20 май 2011
    This application report describes a reference design implementing a battery-less RFID application that includes an E-Paper display, using the PaLFI eZ430-TMS37157 RFID board. The sample application code is implemented to run on MSP430F2274 MCU. In addition to handling the communications and E-Paper display driving, the MCU also controls a DC-DC boost converter to supply the higher voltage required
Серия: TMS37157 (1)
  • TMS37157IRSARG4
  • Semiconductors > Wireless Connectivity > NFC / RFID
На английском языке: Datasheet Texas Instruments TMS37157IRSARG4
